ok....i'm uploadin 'em now in gallery some should b there allready, thanks guys :)
http://www.skylinesaustralia.com/photopost...=&numprocess=10
on those photos theres only couple decals, i stuck on more 2day, and i also got skylineaustralia.com decals on back windows, looks good :wassup:
I work in that neck of the woods so I will probably see you around :) .
i'll keep an eye open, not many gtr's up here  :rant:  c u around mate
You should see mine up there a bit, parents still live there and have I still have a few friends there still. Was up there recently for the Morayfield High 10yr reunion...yeah!
haha, see you around
Hey mud  :wavey:
haven't seen u on the gateway 4 ages!
i'm no longer the same colour as u anymore either :P
a new pic of my car
Nahh been workin on the other side of town.
Thats why everyone's been spottin me on Coro dr etc.
Be back on the Gateway Monday. I'll keep an eye out for ya!
saw slide and freinds at bwcp on friday night, sorry i didnt stop and say hi, what did you guys get up to?
went for a leisurely drive up a mountain and around broadwater after....was reasonably fun...u missed out :rant:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
