ok....i'm uploadin 'em now in gallery some should b there allready, thanks guys :)
http://www.skylinesaustralia.com/photopost...=&numprocess=10
on those photos theres only couple decals, i stuck on more 2day, and i also got skylineaustralia.com decals on back windows, looks good :wassup:
I work in that neck of the woods so I will probably see you around :) .
i'll keep an eye open, not many gtr's up here  :rant:  c u around mate
You should see mine up there a bit, parents still live there and have I still have a few friends there still. Was up there recently for the Morayfield High 10yr reunion...yeah!
haha, see you around
Hey mud  :wavey:
haven't seen u on the gateway 4 ages!
i'm no longer the same colour as u anymore either :P
a new pic of my car
Nahh been workin on the other side of town.
Thats why everyone's been spottin me on Coro dr etc.
Be back on the Gateway Monday. I'll keep an eye out for ya!
saw slide and freinds at bwcp on friday night, sorry i didnt stop and say hi, what did you guys get up to?
went for a leisurely drive up a mountain and around broadwater after....was reasonably fun...u missed out :rant:
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
