i used to play cricket and netball at toombul but have now moved to salisbury for cricket and valley for netball
i know most of the dudes that played cricket at toombul have now moved to kedron
yer, we played a grade on tuesday nites for cricket fora few seasons
had some good competetion there for a while
travelling from teh southside to toombul though was taking its toll
so we finished up
Spotted Drew today near Morton Bay College. Was caining around in mates 32 GTR.
Yeah, I was like, hey thats a smick looking GTR, oh hey the dudes waving at me! *Waves back!* Hang on, wasn't that Dan?!
Also saw a R32 outside work the other day (Computer Alliance @ Mt Gravatt), GTR, light blue, no wing, carbon bonnet, real nice example, anyone know if it belongs to someone on here?
just saw my first ever stagea actually driving around apart from my own. a white one, looked like an autech kit or something, heading southbound near the deception bay exit on the highway.
if this is you, and you passed and waved to a green stagea RSFour that was heading northbound, howdy. only had mine a month but.
that was me in the 260 ..whole car is autech
Has anyone seen me cruising around??? Photo is in my sig. Usually around Aspley, Redcliffe.....
Considering I live in one and frequent the other...I should have...but alas...I have not.
That and no one has seen me either...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
