R32 GTST wine red, mains rd, sunnybank all the way to sunnybank hills. About 5:30pm rego xxx IQR. seen you a few times around that area. ill stop one day in mid traffic to say hi =)
you went all the way to compton rd and then turned around back to beaudesert rd(inbound).... why?? haha
me in white 32
Saw Col this morning with his yellow R33, on the intersection of Gympie rd and Hamilton Rd, around 8ish. nice BOV,lol.
WOW this morning... My BOV went off???
I was granny driving due to the coldness of the engine...
You should see me when the engine is warm... :)
BTW: Its a HKS SSQV... A real one ($600) not a cheap arse copy...
Where were you, i saw no GTR???
You should see me when the engine is warm... :wave:
lol, i thought so, it made a nice sound when you were taking off from the lights.
i was in a mate of mine's S14, going in opposite direction. ill make sure i wave next time.....
Cool cool...
Usually i have a nack of spotting skylines...
Would love to look over the GTR some time...
Also now you mention it I had an R33 follow me to work this morning. It was a non-turbo with billabong stickers on the rear window and the side skirts...
Guy seemed to think it was PWR'ful... So when the revs got to about 6k he let off so the AUTO trans could change gears... :wave:
spotted 33 GTR, 34 4 door and Dave (rhinorebel) on jubilee tce...at around 6ish
Yep, all of us fresh from track day!!!! That traffic was stupid. Someone needs to look at those lights and their peak hour sequencing!!!!!! Hate Jubilee Terrace at that time of day!!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
