Bit slow with my post but spotted a clean looking Black R32 on Bradman Street at Acacia Ridge, near Beaudesert road/Llerroyd road. I think it may have been RBR32?? I was on my way home from work so it woudl have been around 4-5 maybe??
Spotted a black R32 on Logan Rd (near Freedom servo) this morning. Can't remember plates (maybe [***NUG]?), but had the stock wing.
Anyone on here?
are you sure it wasnt you in the reflection of the shop window. Was it keeping up with you?
spotted white 34 4door 73ENA @ Marinellis Performance shop this afternoon
My guess is it belongs to Teena :laughing-smiley-014:
oh, bout time you washed it, it looks better clean.
Hehe, yeah that was me!! The 34 was getting her service done ready for the cruise this weekend. Marinelli's seem really good! I'll make sure it's nice and clean for this weekend at least!
Teena is your U13... a attessa 4wd SR20 turbo one? way off topic but curious cause not many around
Nah, unfortunately its the aussie KA24DE FWD bluey SSS. Still an awesome car though, with heaps of features. I wish my 34 had the cruise control and HUD.
Saw a black R32 on the road in sunnybank that runs along the train line off of orange grove road near Boundary road. I think they were waving, but I appeared rude and didnt really wave back because I was being blinded by the sun and only saw them at the last minute!
Didnt know if it was anyone off of here. So Hi if it was :laugh:
Spotted - Tidy White R32 along Orsova Terrace...Seems to work at Caloundra Council :(
Saw a maroon S1 R33 heading toward Caloundra on Caloundra Rd... got a wave back
^^^^ that was me .. with black mags yes? :laugh:
Edited by Logikal
Didnt know if it was anyone off of here. So Hi if it was :sleep:
hey mate that was me both times :D clean looking? ha! i must have washed it for once before hand.. i think i waved or nodded in approval :D past 2 days i have had my drift tyres on my front as my road tyres were showing steel radials (gulp) anyway i got my new tyres today yay... although, i spent my drift money for june 1st @ qld raceway :P
saw a nice 2 door grey 34 on st pauls TCE today near bowen hills too, didnt catch the plates, about 4:50 pm
and a nice champagne (gold) 33 on corro/inner city bypass tonight also. bout 6pm
Edited by Benno-
Spotted MRO33 this morning about 8.30am on the ippy motorway.
Whoever the knob was in the team spaz (stickers plastered on every window) white 33 driving next to you, just about wrote me off as you were exiting, just before i waved, as he tried to merge straight into the side of me. You might've seen it all in your rear vision mirror. Note to that driver, check your blind spot before you change lanes, as i had to hit the skids and swerve around you, as you still kept coming over even once you saw i was there. That's just rude.
Edited by Miss Niz
Didnt know if it was anyone off of here. So Hi if it was :)
Could have been me, I go past there at bout 4:40-5, seen a 32? yesterday with a white panel or something on the front right???? I fully waved like a nutta??
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
