Spotted a white R31 with black bonnet and stock white R33 at Hungary Jacks Browns Plains, friday night. Spotted GTR, DUBAI on pinelands rd on Sunday, a yellow 32 on middle rd (hot car by the way) and white R33 WKD33 on Sunday arv. DUBAI is the sweetest line I have ever seen......
spotted a red r33 with black rims, near northfield nundah pulling onto sandgate road, had sau stickers....
then spotted a black r34 with i think the tomy front bumper?? pulling onto sandgate road near the shopping centre, ive seen you around redcliffe :P
then on way home from city around 9ish was driving with a 31 white sedan from airport all the way till deagen diviaton
Edited by Silver_R34_GT-T
lol. do u go ther..? who owns that ridicuously huge wide bodied R33.. barely fits in the skinny park spots ther.. :whistling:
yeah i'm there for the next couple of weeks. not in my car though, doing work to it so its undrivable.
havent seen the r33 yet, i'll keep an eye out.
also spotted a yellow 34 at the intersection of creek and old cleveland rd this morning, 7.45amish plates were OOR-34
saw a r34 gt-r vspec midnight purple traveling down logan road
trade plates hmn wonder whos this is :google::P
Spotted the same one in Mt Gravatt
Hot ride
Edited by Along for the ride
Spotted a black 180sx i think his name is MARKIMAK in these forums at the drift practice @ Archerfield this afternoon.
Carl
hey carl.
yeah brother. was a pleasure meeting.. u did some pretty thick smoking skids in the R31 :D
perhaps in a few months with more practice we could do tandems :P
ill catch ya at the next one.
i would say it was you as there arnt many skylines painted in that colour.
did u get urs from the import yard on ferry road?
theres actually a 2door 33 that sits in a resaurant car park across the road from jupiters thats the same colour as mine
wen i saw it i was shocked. its a stock grey/blue colour off a nissan bluebird too
and yea i got it from MJR on ferry road, y u ask??
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
