In all my nearly 1000km of driving over the course of the weekend to ipswich and back from maryborough I only really saw one skyline.
White r33 with nsw plates YLD-33R just off the gateway.
Looked a bit puzzled at seeing my r33 towing a trailer I reckon.
coolio :)
spotted a red R34 GTT coupe at archy drifting :nyaanyaa: nice mate..
the usual brenton being a dead weight ;) u would have made a good pylon mate
DRF76 R33 GTST :) very nice
and camerons R32 GTST 25/30 is nuts... love the ride in it the other week mate :)
:P
spotted silver r34 GTR covered in HKS stuff outside hilton
then spotted a white R34 gtt with the aero body kit in a car yard
and a red v35 Coupe in the same parking lot as the r34
all in Kuching though:)
Alright went upto Bundaberg over the weekend to visit my brother, I dont have number plates but yeah.
1 white R33 looked pretty standard parked on the main street in bundy on Sunday
1 Black R33 with a Kit on it in Childers on Sunday
1 yellow R34 in Bagara on Saturday
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
