always see a silver r33 and r34 in nambour and a r34 4 door in woombye... and a few around maroochydore.... if its anyway 1 here im in a the multi colour r31.... if u want give'a wave or flash ur lights or something ill try do something i always wave but no response :D
oh they didn't wave how rude :(
There you go again, blah blah, just relax. We are like a growing community, some people like to wave and say hi.
Now back to business, spotted a black / charcoal r32 on mt cotton road yesterday at 16h15. Both driver and passenger wearing blue uniforms. One male and one female, looked strikingly similar to Qp, they were on a roundabout mid flight so it was hard to verify 100%. :D
Edited by 1C3B3RG
