Spotted the TUF032 on nursery rd on Saturday around 11am, I was the black 33 pulling out the shell, gave the nod and got one in return. I was impressed the old fella was driving it (noticed him earlier while working giving it some stick on logan rd).
Saw about 4 silver r33 series 2 lines between brwons plains and the gateway on saturday... and a few others I bearly remember.
Also sometimes spot a green r33 non-turbo coming into work to fill up. Don't know if you're on here but I've spoken to you a couple of times, good luck getting a turbo conversion :(
yeah did ge the conversion allk is good:D cheers hame! :(
spotted a nice maron r33 on newham road today we had a bit of a burst together, guy was cool. Then on the way home from underwood on logan road spotted a nice s2 going the otherway (Towards underwood) we did the wave! cheers hame
Hi all
Im daniel, I drive a white r33 line around redcliffe area. Its a stock 95 s1 with updated front bumper and mags. Its got the SAU stickers on side windows and a AUTOSHOP.NET.AU sticker on the back. Cant miss it. If you see me wave or say hi.
I spotted today a white r34 at toombool and also a maroon r33 at chermside today.
Yesterday on logan road just after 6 i spotted none other then my dream boat!
A beastly R34 GTR in bayside blue.... oh god i nearly came in my pants! :)
Edited by RB_turbo_bitch
Hi all
Hey, fairly sure i spotted you the other day coming off anzac avenue heading for boardman road roundabout
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
