I was heading down the coast yesterday (sunday feb24) in the afternoon along the highway from brisbane and some girl and her boyfriend i guess (the cute girl driving) over took me pretty fast in a maroon/red R33 GTR skyline i think or at least with a taerbo. Didnt want them to think i was rude for not racing them so if they are here hey hey guys! very fast car you got there hope you had fun down at the spit - we saw you as we were leaving and would have turned back to say hi but didnt want it to be all weird.
but yes... your car is fast and i was most impressed.
Spotted 53XYN GOT04 MYA31 on the East Coast Dyno yesterday... making huge power figures! :(
who.. ?
car... yellow 32 51PRY
where.... on kessles road and all the way along the ipswich motorway til i got off
WWII... my GC110 sky
Hey there! Nice car! :)
Sorry I didn't get a chance to tell you what's done to mine!
Spotted "NUR34" in Moss street round lunch time...
Was out getting bits and pieces and spotted her, looks the goods...
Also spotted POO123 o POQ123 this mornign on the gateway near the boondall entrance/exit heading south...
Spotted 34 4door with the plates "UR FACE" what does that mean?
Where did you see me?
And it's like saying "Your Mum!", or "in your face". Or when I sit on the bonnet, technically I'm sitting on your face... :D
Spotted WAN17 silver R33 S2 on the M1 this morning blasting through traffic
also spotted GO Wld Yellow ferrari on upperedward street with hazzard lights on with smoke out the engine
haha yeh coming onto the freeway am MtGravatt in the shitty peak hour around 8am, you were behind DMD 15 wide body S15
Oh, I knew he was online but didnt know his name...
The bastard didnt wave... :)
(i was in the SS)
Who waves to bogans in V8 utes? :D
Spotted Grey 33 plates "BESURK" parked outside Darra Cementco Bowls Club
I was parked right in front in the 33 4dr going in for an after work cool of drink
Edited by Traditimeour
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
