just left nambour rsl and saw a r34 steaga plates xxxga was a nice car... pitty about that little ramp that sounded painful lol... and quite a drop... also a r32 parked out side the royal gorge or somewhere in the main street of nambour white in colour also looked nice
spotted a silver 34 2 door headin up beaudesert rd and turning onto boundary rd this morn at about 7:50am... looked over for a wave as i went past but u were focused on the car in front...
if your on here and didnt already know, ur right break light is out :)
also yesterday spotted a white 32 with a cf bonnet, you let me infront comin down i think it was brownsplains rd turning onto the mt lindsay hwy, Thanx!
I think I see that same white r32 on my way to work, just past park ridge.
white car, black sprayed bonnet and black rims. looks pretty clean. he lent me some jumper leads about 6 months ago when my r33's battery went flat.
Also spotted Teena's 4 Door 34 in HPI! :wave: from the NS.com cruise
Hehe, yeah, after all the controversy there was surrounding that cruise...
Pity i didn't have my nismo mags on back then though.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
