Spotted 73ENA pulling onto the Ipswich motorway of the Centenary roundabout this morning
Spotted you too! :P
I knew JEZ42 was familiar, but couldn't think who's it was... Looking really nice and tidy! Tried to catch up to give you a wave but got stuck behind a damn truck and a slow as tarago just before the Darra exit which we both took...
CME 33 parked across from the gardenway/bmw dealer on Monier Rd.
Then just after going on the bridge across the cen10 highway some silver 33 with a heap of vinyls. Plates I think were 489 XJ# I'm probably completely wrong with that.
Today has been a very weird day for driving around, so many people doing very odd/stupid things.... No skylines though :)
spotted a white turbo r33 about 6ish comming out of a street in woombye i was walking home number plate was **mo8 or something like that tried to see if it had sau stickers :thumbsup: had a subi behind u
hey guys....
i have recently brought a r33 and noticed a few "sau" stickers on skylines so i thought i would google it and i guess i found yous!!!
now that i have joined can someone help me out getting stickers?
Wha77
Last time I googled SAU it came up with porn.
On topic. Some black r33 with stock zorst at mt.om KFC at like 3pm today. Didnt really look just had to say saw something otherwise this thread will turn to trash.
Saw a Black R32 today, Had a chrome "R32" badge on the back. The chick driving didn't look too bad as I drove past either :laugh: . This was on Kingston Road just past the Kingston/Compton Road intersection.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
