Saw a nice looking R33 (110 HCT or something like that) at the roundabout on moggill road in indooroopilly. The driver turn into my lane right up behind me. If you are reading this, i did gave you a wave and i could have sworn i saw you smiled.
btw, nice wheels
GenesisR32
I'm Michael, 21Y/O and poor because of skyline payments. I drive a white 32 GTST. Engine is Stock bar pod filter, bit of suspension work though :D I toot and wave at other lines...don't always get a response.
Bryanlee, were you cruising around the city last Friday night? I was with a friend in his VK commonwhore (I was friends with him before he bought it). I think we pulled up next to you near city rowers? Pretty car ;) but if it was you it would mean that the paintwork was fixed up (ie - no bog)?
Whilst we are on the subject, who owns the Gunmetal R33 GTST that blew away that worked WRX along the Robina Parkway down on the Gold Coast last Saturday Night week?
Looks like a Mspec bodykit with Black plates (can't remember the numbers) very nice car.
Man your car is quick, that Rex has had me twice in the last week (and I usually take them) But you fed him his lunch, it was so cool, he was so pissed at the next lights cause me and my mate were laughing at him.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
