Spotted a white new GTR on my way to work on the M3 today. I work out at the PA hospital so it was headed mostly that direction. Personalised plates which were black on white and the damn the car is sexy. I would post the plates up but just incase they aren't a member I wont.
alex hill last night (heading towards coles) seen a nice looking black 33.
thumbs up but wasn't looking :)
i was in the white 33 555kkr
I think i saw you.....we parked just ahead of you for a few minutes.
spotted 2 today 1st was a gun metal grey 32 gtst on boundary road off beaudesert road i pulled out of side street and ended up behind you.
2nd was along beenliegh road a silver 33gtst plates 0NY01 was cruising behind you for a while till you turned near vid ezy. was in the white 33
Spotted a white R34 ith a freaky tall rear wing... Stuck in the traffic on the riverside express way today around 1:30 - 2pm...
I was the smart arse flying up the outside of the traffic on the bike who tooted... :banana:
Maybe that was me. Say hi to everyone, My name is Alfred and I am new in here. want to meet more skyline drivers and friends. If you see an asian dude with a white R34 around that will be me!!! :bunny:
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
