Spotted a white new GTR on my way to work on the M3 today. I work out at the PA hospital so it was headed mostly that direction. Personalised plates which were black on white and the damn the car is sexy. I would post the plates up but just incase they aren't a member I wont.
alex hill last night (heading towards coles) seen a nice looking black 33.
thumbs up but wasn't looking :)
i was in the white 33 555kkr
I think i saw you.....we parked just ahead of you for a few minutes.
spotted 2 today 1st was a gun metal grey 32 gtst on boundary road off beaudesert road i pulled out of side street and ended up behind you.
2nd was along beenliegh road a silver 33gtst plates 0NY01 was cruising behind you for a while till you turned near vid ezy. was in the white 33
Spotted a white R34 ith a freaky tall rear wing... Stuck in the traffic on the riverside express way today around 1:30 - 2pm...
I was the smart arse flying up the outside of the traffic on the bike who tooted... :banana:
Maybe that was me. Say hi to everyone, My name is Alfred and I am new in here. want to meet more skyline drivers and friends. If you see an asian dude with a white R34 around that will be me!!! :bunny:
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
