Spotted 83CKS this morning....I was hiding on the bus. Car pool'd then bused it to the valley from southbank, in preparation for tonight. :P
Also spotted SIC-33 didn't look all that sic....needed the main sail set to be more sic.
I spotted brandon in his 33 gtr on turbot street this arvo, im riding my bike so i make a very obvious wave towards him, and i get nothing......
these gtr drivers, think they can snob us regular type people :P
Haha... sorry man! Didnt see you at all. I'm probably on my way to pick up my wife from work. Cheers!
green R 33 S1 on creek road at about 4ish.. got a nod and thumbs up .. was in vlue 35
Also silver V35 stock on newham road around 4.30ish
Spotted John (nis035) at tafe ground yesterday arvo.. was in pulsar
spotted becks again....
last night on the logan motorway.
I was just coming off the wembley road exit with the maxima (debadged) on to the motorway.
then I briefly flashed you with my beams of course :(
every morning i see this r33gtr blackish blood red pearl white gt stripes over car red pin stripe around the white and red pinstripe wheels this thing looks amazing he heads towards the northside at about 7am
Sorry to the white skyline I passed on ruthven st, saw ya wave but I was too slow.
brisbane??? could have been me, i was really lost trying to get to ipswich m'way
also spotter SMR33 along gateway this arvo, chick driver red 33, nice too see.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
