Spotted a hot R32 on Lytton Road, Bulimba last night. It was dark so I couldnt quite make out the colour but it had green through it.. Was sexy. If you're on here I was behind you in the ute :P
Also saw someone getting into a silver R32 gtst out the front of Goodlife Gym in Morningside last night. :-)
Spotted a purple r32 with black bonnet on algester road about 10mins ago.. (think i used 2 see u most mornings on the way 2 work) but have not seen u in ages..
Lies, I was just there and didn't see 'said car' :P
You a northside boy too?
Yeah mang. My friends car is the horrid silver 33 with a shopping list and a "GTR" spoiler. You've probably seen him around Albany Creek/Aspley/Chermside.
Stock White 34 in at Portabella's tonight in A/c.
Saw 94BNR.....the 'gabnermeister' on Beenleigh Rd...was a couple of cars back in the wifes car, Mr Miragi!
Ahh, Mr Miragi, we meet again. Rare sight seeing Gabnr out and about, was blowing the cobwebs out of the cylinders.
Haven't seen any shopping list 33s around lately. I'll keep my eyes open though.
Don't get up that end of A/C road much unless I'm getting KFC. I refuse to go to the Aspley KFC as they deep fry their chicken in aids.
I'll make sure I wave to any white 34s I see :) (any chance you were the stock as 34 I saw at the Aspley chemist a few weeks back?)
Edited by Isola
I'll make sure I wave to any white 34s I see :D (any chance you were the stock as 34 I saw at the Aspley chemist a few weeks back?)
Ah, sorry to confuse but I unfortunately don't drive a liner, I meant that I saw that car there tonight. I have a silver BA Xr6, I do get around the area a fair bit and wave to a few of the liners that I know wave back haha.
Edited by hylian
Spotted Black R34GTR near Burleigh heads last friday night, very clean white R33gtst on bridgeman drive West Burleigh thursday night, Purple GTR with no wing & black bonnet at Cotlew street roundabout thursday arvo, Black R35GTR opposite JB Hifi Bundall on thursday arvo & a awesome silver R33Gtst I think a fair bit everywhere I turn almost-got cromies on it & looks sweet
white r35gtr springhill - coming out of the pool down there on gregory tce about 7ish
50FLI the other night, see it a fair bit around brisbane
and some arab douche in his r33, pumping some gay bolliwood crap music, driving real slow through the city on wednesday about 12pm
Edited by defari
two tone silver r33? 4door with a fox sticker in the rear screen this afternoon. saw the same car a few days before heading along the same road, I was in the ba xr6 and slowed down to see if there was sau stickers and i think you were trying to stay behind me after that haha.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
