46n2 - good show of restraint.
I'll comment. Drinft King Motorsport Geebung will be at Jamboree, worth dropping in to chat with them if you live north side and need riceline work done.
Saw a few nice lines out last weekend, a black R33 friday night heading into the city on gympie road, and a blue R33 heading out of the city saturday night on gympie road. Nice to see some line owners who smile and wave too :)
Saw a few nice lines out last weekend, a black R33 friday night heading into the city on gympie road, and a blue R33 heading out of the city saturday night on gympie road. Nice to see some line owners who smile and wave too :D
Hey locutus_of_bris, you wouldn't happen to know jolly Geoff would you? :)
im from the sunshine coast. i drive a white r32gtst stock as a rock (for now). right side of front bumper scratched. my own stupid fault. my garage wall got in the way. numberplate 102-ICR. usually out on the weekends at mooloolabah and maroochy. sometimes stopped at the caltex. feel free to stop say hi.
my names daniel. and i too am an alcoholic. :bahaha:
Hi Shane.
Yes, I know who you speak of, jolly Geoff is a new name for him though. He mentioned he knew you so I guess this puts it all together.
I'll be up your way saturday the 4th - then heading up to Gympie sat night for opening night of speedway then back to the gold coast sunday. Don't often cruise up there though and haven't seen many lines up there (know a few though)
Oh, also saw a few nice lines revently.
Lime green R33 heading north on gateway heading into toombul - colour certainly stands out
Dark Grey R33 - heading up gateway yesterday and ended up 1 street from where I live in Petrie. Looked very tide and original (so quiet too). I wasn't in my line so wouldn't have stood out like normal :(
Originally posted by chaos
locutus were u around milton/paddigton area yesturday arvo bout 3:30ish
Hi Chaos,
Only just saw this one, and no, can't have been me. My line is now very unique, has a nice white graze on the rear left corner. I was in the city all weekend 2 weeks ago, and saw a few lines out and about, as you would expect
Originally posted by BelGarion
i think i saw nexus9 cruising the espy a weekend or 2 ago
plates nex059
silver 33
Yep that was me :cool:
but it is gunmetal grey :rolleyes:
I want my car to be the colour of yours, love the ice green.
Or is it arctic green? Can never remember.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
