went ballina and back last sat and spotted 2 cool cars
1.turning of to broadbeach
2.Buying some t-shirts at carrara
Fitment on WRX...Unpossible!
Spotted Astrotristan on Coro drive in the TRD Mazda.
spotted, r32 gts-t out the front of my shop. and i think the owners mate just snapped the key off in the passenger side door. and for some reason thinks that the nearest locksmith or at least key cutting place is in a shopping centre a bit from here, despite the fact that there a key cutting place next to my shop, and a locksmith about about 100m up the street.
i'll go and see if they need any help soon. they aren't near the car at the moment
EDIT: they seem to get it sorted.
u dont remember where u saw a red 32? alzheimers at 13?
lol at my own insult
but i saw it when in trouble with mum and i think to clarify it was quite close to the cab state high school [mayb at takeaway near there]
yesterday
silver r34 gtt zorst rims and xenons
black s15 kitted zorst fmic
wrx with zorst and tail lights
granny driving a different wrx
all on walkers road mid afternoon
Edited by rb2634datto
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
