red r31 skyline at the same maccas as the red r32 [morayfild road next to sizzler]
red r33 gtst at morayfield tavern [same street by the kfc]
gray r33 gtst on caboolture river road no mods most likely [very quiet]
EDIT: the gray R33 has no aftermarket exaust as stated above in fact probly no mods at all.
Edited by rb2634datto
I wasnt is the skyline, but only live around the corner and saw u on the way past! I see skylines everywhere when im not in mine ....
Ah ok.
I may be up in that area every few weekends, might see you around. :dry: hopefully in the skyline.
White 33 S2, chromies, GTR wing and a set of side skirts (400R-ish??) that were nearly scraping the ground on the Bruce Hwy this morning, damn it was low!
Was it the one with 20" chromies and the "ADHD Racing" sticker covering the entire back window?
White 31 coupe on Boundary Rd in West End at lunch time today
OLS033, tidy looking back 33 (in case you hadn't already guessed) about half an hour ago on Anzac Ave
Nah 17/18", it may have had a sticker on the back window if I'm not getting it mixed up with a Skyline I saw the other day but it was only a dinner plate-sized one in one corner of the back window. The skirts were maybe 40mm off the ground :P
Edit: can't find the exact ones but they looked similar to these: http://www.carid.com/images/wheels/zen/type-r-chrome.jpg
Nah 17/18", it may have had a sticker on the back window if I'm not getting it mixed up with a Skyline I saw the other day but it was only a dinner plate-sized one in one corner of the back window. The skirts were maybe 40mm off the ground :)
There's one from up Deception Bay way, that's running 20" bob jane chromies (which by the way, look worse than the aids infested ones you saw/posted) They're like nipple shields!) and has a massive sticker covering the whole rear windscreen. It's about a fly's dick off the ground. The guy that drives it is a complete bell end. He was a year level above me at school. Everyone hated him then too.
And whoever the pole smoker is in the maroon 33 that was doing limiter skids and tokyo drift u-turns outside the Aspley bowling alley before... Thanks asshole. I live across the road from the place and have a maroon 32. As far as the neighbors or cops will be concerned, that "red skyline" was me. :)
Edited by Isola
Actually I might have seen that one before! Well, maybe...
There's probably more than one fitting that description but a white 33 with blingy wheels and a big sticker tried to get me to race him on the Bruce Hwy one day a year or so ago, he didn't get the picture even after me indicating no followed by a good 5km of ignoring him, then tore off at a big rate of knots when I took my exit. A-class flogger.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
