im just down from the train station.. ^^
Would you be the silver s2 33?
I normally see :
Silver r34 - only time I saw the driver it was a fem.
White 33 s1 - Aftermarket exhaust, wheels etc
Black 33 s1 - Same deal, Gold wheels
And er. Others. I can't ever remember them all.
Have seen a few times a Black 33 GTR with polished silver wheels and GTR82, Silver/white 33 GTR.
I normally see :
mines a white s2 33.. i usually see a silver 33, a black/midnight purple 33gtr getting around newmarket / alderly
also a silver 4 door 34 usually parked on my street.
Edited by defari
It's true, only the cool ones don't EVER get spotted. Infact we're in a secret division.. I don't really like saying it too often but we're STEALTH. It's a hidden forum on SAU that the non-spotted people talk about how well they did not to get seen that day. It's all about not being spotted.
I guess i am also in that "stealth" group then since ive only ever been spotted once on here lol :D .. I did see a few skylines down the coast today, but none with personalised plates so i cant remember :D sorry.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
