followed a maroon 33 with the plates EER33 from cooroy onto the highway to the bottom of black mountain. i have the following observations to make. 1: one of your tail lights is faded so it is more yellow than red. 2: your car is running pretty rich. i could smell it inside my car with the windows up.
now for comments on your driving.
you weren't able to stay within the lines. for the few kms that i followed you, you were constantly varying you speed between 5 to 15km/h under the limit. then when we go to the overtaking lanes and i tried to pass you, you sped up to 20km/h over the limit so i couldn't get past without flooring it, and then you slowed back down once i was past. you're a deadset dumbass. you may have thought i was wanting to race you because i was constanly getting closer and further away, but that was just because of your poor ability to hold a steady speed meaning that i had to keep slowing down and speeding up.
Try T-Mac, Power Street?
ah yes, that's right. think he may have worked at ford before T-mac, but i could be wrong.
this morning i spotted a white r34 (possibly GTR) with gold wheels heading north on the highway in gympie at the top of the golf course. i was the fella on the bike (in lycra) heading back into town.
and on wednesday i spotted a silver r32 4 door that belongs in the "what not to do to a skyline" thread. it was on steve irwin way heading towards landsborough. had some mildly ugly front bar, eyelids that covered half the headlights and had a strip of LED driving lights under each headlight.
I see loads of young skyliners out southside way and always give the captains wave!! Say Hi back!
34 midnight blue sedan 611MAB is the daily with gun metal rota boosts or on weekends the 34GTT white coupe with GTR wing and BBS wheels.
Must put a SAU sticker on one day!
yeah that's the one. used to live on rifle range road across the road from my grandparents place. i think the guy who owns it works at ford/nissan/mitsubishi.
yeh i used to spot that every morning too on the way to work
Think i followed blackers for a few minutes heading towards 7eleven on the morayfield road, hell no i wasn't waiting 3 times for those lights before i could go. they are a pain in the ass
I moved to Toowong last Tuesday and haven't seen any Skylines around the city at all. Then I went to Sunnybank today and saw heaps. Best two - a very clean looking silver R33 GTST coupe at Sunnybank Shopping center and an R34 GTT sedan with a chunky URAS bodykit - MRR34.
Edited by R34mac
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
