ahaha some ding dong put a old v8 in a 33.....front bar too?...get out
bet it rips a skid alright
oddly enough, the bars fit pretty well. there was a guy in gympie (think he was even a member on here) putting a rb25 into a commodore ute and he had the r33 front bar on it. didn't look that bad (from a fitment point of view)
I don't get this obligation you think there shiuld be to wave at other skyline drivers..
You bought a skyline.. grats
Eh I wave to other nicely modded skylines when I'm in mine, makes my day when I get a skyline wave :P
Oh...don't you know your abomination is also called the Japanese general lee? I know it needs a hemi not an LS1 but you do almost have the correct paint job and the right number of cylinders.
Haha ok deal lol
It does look like it wants to be american! And i hear its a bit thirsty?
Japanese general Lee does sound better than "the abortion/abomination" :yucky:
Oh...and i spotted another R35 today, white, boring...driving real slow in the overtaking lane at 95......WHY!!!
Shit oath it was, bloody thing sucked fifty bucks worth of fuel to go from Gatton to maringadan and back, equates to about 22L/100 :/
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
