this is cool. Well I'm Bryan 18 year old - and i may look like every other asian in Brisbane Sunnybank. except I'm from SINGAPORE. And I'm NOT a rich daddy's boy who got a "free" skyline. Mine is the one which has cheapo mods to it because I'm currently poor and jobless. Got my car vandalise yesterday btw, so if u see a maroon car going around with body filler everyone - ITS ME!.
Hey bryan, how's your car now, have you fixed it? i also have a maroon R33 and have another friend who has a maroon R33, maybe we should make a maroon R33 Cruise :)
my car 801GYY R33 St Lucia, close to UQ
Hey bryan, how's your car now, have you fixed it? i also have a maroon R33 and have another friend who has a maroon R33, maybe we should make a maroon R33 Cruise :P
hey yoparata... you go to UQ as well? i'm in indooroopilly and drives to school everyday during the semester. currently doing my MBA there. give a wave yeah if we pass along sir fred schonell dr. mine's the black R32 with white enkeis rims. :P
Thursday or friday last week it would have been me.
But I definetly don't have my car this week. And I tell ya what, I don't think my mum's barina has used sooo much fuel in it's life!!! I've gone through 1/3 of a tank in 2 days :S Air + lots of accelorator to get places == bad fuel economy :S
hey Guys
Well i joined this site about a month ago but never introduced myself, im wade and i drive an R32 red wine skyline, ive only had it a few months so i havent done to much to it yet besides the usual like exhaust, filter and some gauges, so if you see me around ( i live on the northside of brisbane) give me a wave.
Cheers.
hey guys i've been on here a bit as i like to refear it to "the skyline bible" hahah but n e ways names Michael im on the northside of brissy and drive a R32 GTST in gun metal gray with a "FILO" sticker on the side... whats doin thurs night strutto? thanks guys!
Peace
