Hi All,
Was wondering if you would be able to help me out. My friend got his 2001 3 CT9A EVO 7 stolen around April this year from Cambridge Street, Penshurst SYDNEY. The police have been absolutely no help and I was wondering hoping you could spread the word to see if anyone may have seen or knows anything!
Thank you so much!!!!!
These are the details:
Make: EVO 7
Model: GH-CT9A SNGFZ
Colour: White
Rego when stolen: JDM3VO
VIN: TBA
Chassis No: CT9A -0004702
Distinctive features: whole rear of the car is an EVO 9 body.
Any info: [email protected]
10403304_10152378223891954_70520766048871779255_10152378223856954_17045818841732
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
