Saw John in the v8 cruising around the city ... first time ive herd the V8 roar! :)
v8???? wot v8.....v8 skyline? who? where??? tell me...TELL ME NOW!!!
lol
obviously there is more than one of us now eh?:burnout:
got the thumbs up from a black33 going back towards the city from bardon... not sure the name of the road.
HEY! that was me mate!! along Simpsons Road (i think) That was my last day of the GTS-t....she is now sold and gone to a new owner ... it was fun while it lasted.
06TST is a very nice looking white 32..... good mate of mine. ONE HKS turbo on the way for him!!
Saw a white 33 with a young lass driving the bf in the passenger, along the SE freeway last nite.  It had bodykit, exhaust, filter and bov.  I think i surprised them a bit with the rather stock setup of the 32.
hey dude were use having a few little, ahh getting up to the speed limit quick runs and a red vy commonwhore came flyin up your ass was it coppers
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
