I am a bit confused, we have had this at my work (internet cafe) for about 4 weeks now, i played it.... to be honest i did not like it, maybe because i never liked the other CoD games. However my mate sat there for a good full day (seeing as the hours consist of 11am-3am) and towards the night he said... wow i clocked it already. Does this sound possible? If so... i am glad i did not buy it.
  • Replies 131
Easily finishable in one sitting. You buy the game for the online play, not the offline.
theres a cheat where you can just sit in one of those booths and just wait it out, but thats a bit anti-the-point... try and back yourself into a corner so that they can only attack from one or two directions... and bury yourself with claymomres dont worry about spreading them around.
I hired this game a few weeks back.. clocked it in one night :down::)
hired it again and gave online a play.. now went out and bought it and lovin it :D.. lvl 21 now after about 10 hours of online play
did that booth thing but... when the chopper gets their i keep on getting killed picking up the other dude and running back..
but in the end i bought it for pc and am now up to lvl 16 in about 5hrs.... so easy compared to ps3 *to connect to servers n stuff*
top game i bought it last sat and finished it sunday (for pc). multiplayer is great. ive played CS & DOD old and source. have any of u tried the mod called insurgency. thats pretty good for a while.
multiplayer has engulfed me. im on every afternoon and sometimes at night. my player name is killerkutz.
question: do ps3 run separate servers to pc online?
I was trying to creat an SAU clan on 360 but it wont allow it. I think it thinks im swearing. Theres alot of things you cant have as a clan tag which sucks. I wanted simply XXX but its not allowed.
Another reason why Xbox sucks :D I have [sau] as my clan tag on ps3. Anyone that plays it on ps3 should join up! I think I'm the only one...
If you play it on PC come over to Ministry of Gaming server, the server is set to hardcore mode. So no hud and it only takes a few bullets to put someone down.
One bullet unless using juggerstand then it's 3. Hardcore is really the only servers I join now.
If it's H/C and shows up in the list with people on it I join mostly the GSA H/C TDM.
Working on gold AK that I will never use just like my gold mini-uzi and unfortunately the gold sniper rifle is the Dragunov. Very disappointing, I wanted to use a gold mini-uzi as my secondary (Overkill perk) when sniping but it wasn't to be, can't choose a camo pattern for a second primary weapon.
I currently detest the G3, it just does not suit my style at all but I still need those headshots.
Ha, G3 with reddot scope FTW. I run around and pop one, MAYBE 2 shots into people and take them down.
I use the Dragunov aswell quite a bit. Its good for taking quick shots at people. I'm still only on lvl 32, but at the rate i'm going i'll be 55 by the end of the week.
I was lvl 55 in two days of play and really it's doable in one with enough active servers.
The G3 is a single shot kill in H/C but it's extremely unreliable unscoped/unsighted when moving around. It's a camper's best friend but that's not what I do. The M40A3 is definately the best sniper rifle with high damage and accuracy but the semi-autos have the advantage in an 'oh shit' situation where you can just fire off a mag in the general direction and only one has to hit.
The M60 rivals the G3 for single shot accuracy and damage and it has higher penetration.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
