As patrick suggested id be interested in a magazine shoot with the 32 and the 260rs.
Still running the 260 in, few more kms to do then i should be rolling around 320awkw. Engine bay has been cleaned up a bit aswell so looks good in pics.
  • Replies 97
Have to agree with everyone here regarding the HPI thing - high perfomance imports, wouldnt dare for the life of me even consider mine lol, mines rice but i dont care.
I agree with what others have said, this offer is for cars that have show and go .. agree that grims 2 cars would be perfect! Or 'whathisnames'. Both good examples..
Stop fighting over it tho guys :S
Hey all I have been in contact with the editors and i will be in contact with those who they are interested in please allow me some time to get to you.
I have not forgoten
cheers
Andrew
Well I just wasted five minutes of my life reading thru this thread and stopped twice to check if i was on NS.com....
For F#*!Sake people I have seen shitbox suzuki cuppacinos etc in HPI so lay off the n/a skylines already.
PURESX is about to be released on a magazine and dvd so he will probly be out
+1 for watsisnames r33 ...that is hot and both GRIMs machines too.
^Martin, what about your car? You've definately got what it takes I believe, looks power etc? Send him some pics :O
Maybe even a dual feature with Hostile and Snyper?
dooooo iiittttttt :worship:
thats if youve got your passangers seat in :O
Martin:
Personally, I wouldnt say your paint isn't show worthy. I would say its a beutiful street driven car. In photo's in the magazine it would still look amazing (like above) and you have plenty of interesting information with the current setup as well. Im sure Snyper is the same, so just put it in! :rofl:
i didnt see any flaws in that paint job, even if there were they could hit it like they do with the models.
bit of airbrushing here and there and she's good as new :rofl: something like my datos rusty paint job may take a lil more work though
G'day all,
Thanks for the 'votes' for my car. I wouldn't say my car is a typical Autosalon car but I guess it has a few of the major areas covered.
Andrew (nuttsHunglow),
I've never had my car in a full feature in a national publication. If you, and more importantly your editors think that my R33 is of the required standard (and is what you're looking for) I would be honoured to have it in a magazine.
Cheers,
Matt
Thanks, guys.
I'm not actually sure, Steve. They were on the car when I bought it back in '98 or '99 - whenever it was. Volk Rays is all I know. I'd like to get 18s or 19s but I'm not ready to give up too much sidewall until I've achieved all I can on the drag strip.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
