cheers guys
225's it is!
oh also..if u have the ATTESSA system, ie r32 gts4..is it realli bad to have different width tyres front and back??
If the front and back are different widths, apparently ALTESSA goes slightly retarded, so keep them the same or as close to the same as possible.
https://www.sau.com.au/forums/topic/193372-r32-rims/#findComment-3474136
i've also heard of people complianing about the ATTESSA going funny just by using different brand tyres front and rear.
Edited by QWK32
https://www.sau.com.au/forums/topic/193372-r32-rims/#findComment-3474179
width does not matter. DIAMETER matters. but of course if you have different width tyres it can be tough to get some that are different widths yet the same diameter. so in practice it's safer to just stick to the same size all round.
https://www.sau.com.au/forums/topic/193372-r32-rims/#findComment-3475203
If they are only 6.5" Id go a 205.
I'm running 215s on an 8" rim and that's not stretched at all, you will get better grip/traction getting the proper sized tyre, wider doesn't mean grippier. Also if its awd get the exact same rims/tyres all round or the awd system can play funny buggers.
https://www.sau.com.au/forums/topic/193372-r32-rims/#findComment-3478423
yeah i noticed every time i put mismatched wheels front n back on my GTS4, my mates IS300 gets all retarded.
its ATTESA people. two T's, one S, no L's!
https://www.sau.com.au/forums/topic/193372-r32-rims/#findComment-3480916
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
