I have read heaps of threads about rough idle, stalling etc etc and it seems to come up very often that intake leaks are the source of the problems.
Its pretty hard to find a small leak when the car is running by listening for it, especially with the noisy engine fan, and it can get messy with a can of wd40 or something similar being sprayed on every seal and clamp.
So I have been thinking about another way of checking for leaks.
Has anyone considered making a blank that fits inside the rubber hose on the intake pipe where it bolts onto the throttle body, and another blank that fits over the air flow meter where the fliter attaches. Then fit a rubber tyre valve stem into one of them and pressurizing the intake system to say 20 psi.
It would be a lot easier to listen for leaks this way when the engine is off. Also I was thinking you could not have a blank on the throttle body pipe, but instead put one on the dump pipe/exhaust tip and pressurize the whole intake/exhaust.
Can anyone see a problem with this? Im thinking of making some blanks up to check my engine but dont want to damage anything in doing so.
No problem, in fact i have seen kits for sale on the internet for this very purpose. I think it would work well.
I wouldnt go where the air flow meters are, i would go just after the turbos. Turbos them selves wouldn't be 100% sealed around the shaft.
Edited by GTR1993
Already been done before. Here's the general instructions.
You can do a leak test.
What you'll have to do is,
1. take your pod and AFM off.
2. use a baked bean can (full) and put it into your rubber intake pipe (assuming its still the stock one).
3. tighten up the hose clamp onto the tin creating a seal.
4. Open the throttle body with a brick on the accelerator pedal, so you can read pressure on the boost gauge.
5. take a hose that is plumbed into your intake between the turbo and the plenum or off the plenum itself.
6. Get an air compressor and pressurize the system through the hose and get someone to read the psi on the boost gauge. you only need about 5psi. you can use the compressors at the servos.
7. Listen for a leak. And use the soapy water in the spray bottle to find exactly where it is if need be.
It is easier to find a boost or pressure leak using this method because the car is not running and is easier to hear and locate.
Thanks for the feedback guys, it certainly seems a better way than trying to listen for a leak when the engine is running. Not surprised its been done before tho.
Funny to hear the different ways people use to plug the intake up. Maybe jam a spud in there, it works well up the exhaust :huh:
I forgot to add, this is if you've got a mechanical boost gauge installed. But it will pressurize your plenum to check for leaks on it also.
Interesting you say this about pressurizing the plenum. This must mean that rb cams have 0 overlap. ie only intake or exhaust open at any time? Therefore pressurizing cylinders without losing pressure through exhaust ports is possible?
I did it on mine. My boost gauge is taking its signal from the plenum so I can only conclude its pressurizing it.
But i have heard of pressure being lost out of the exhaust which means they will have overlap.....I think.....enlighten me.
The rb25 plenum can be pressurized without the air leaking through the exhaust valves. I just tried it and the first time there was a leak, but i cranked it over a little bit and it sealed up. Removed afm, blocked the intake pipe, and pumped it up to 5psi through the fuel pressure reg hose that goes onto the manifold. :P
Did mine after some recent tuning issues and found a few small leaks. Got a piece of pipe and welded a hat onto it in to whichwe welded an air hose fitting and clamped it on behind the afm. Worked a treat and helped us solve a couple of niggle issues that has plagued us for a while.
I wouldnt do another build without doing this before it went to the dyno. :D
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
