Item:RB30DET From My R32 GTSt
Age:Less than 5000km
Condition:Excellent
Price:18000
To Fit: Skylines R32 - R34 GTSt / GTt (What car)
Contact:Babak 0424 159 779 email: [email protected]
Ok guys its time for a change for me. the Running gear is as follow:
This is a combo of RB30ET (Series II) Block and R32 GTR RB26DET head.
Block:
* Series II RB30ET block includes:
* All Block Preps.
* PAR Competion rods
* Arias Pistons
* Nitrided, Heat treated, shotpined, balanced Cranckshaft.
* RB26 Head Includes:
* Ported and polished
* JUN 272` and 10.8mm lift Camshafts Exh. & In.
* JUN type 2 Titaniun retainers
* JUN Heavy duty valve springs.
* Fedenza Cam pullies.
* Custom V&E Rigoli Racing High mount Exhaust Manifold
* Turbo & wastegate:
* Turbo is a custome Precision Turbo chargers T04Z with 1.15A/R Exhaust housing and rated at 900HP.
* Tial 38mm External wastegate with 11 PSI spring
* Drive train:
* In this deal you shall get a Series II RB25DET gearbox with a OS Gikken Twin plate Clutch and Tailshaft.
* Other Items:
* E-Boost2
* Exhaust system
* EMS 8860 with sequential Timing
* PWR FMIC
* Bosch 044 Fuel pump
* SARD 800cc Injectors
* FORD throtle body
* 2 x EMS Ignigter Modules
* Custom Oil catch can
* Custom Cross member adaptors for R32 GTSt Conversion.
The car has made 368.8 RWKW at 15.5 PSI and had run a 11.2 quarter with 1.58 60ft at 122mph. (Before the headwork and runing only 12.8 PSI)
Ok people, this is what you get for my asking amount. People who are in the marken they know how much Time, Money and effort will they need to build this type of engine. So PLEASE NO stupid offers or comments and PLEASE Only Genuine buyers for this deal so they can appreciate what they get.
All the work had been done By Vince and the boys at V&E Rigoli Racing and they can vouch for these items. Some of you might know the car.
If any of you is interested in the whole car you are more than welcome to contact me on my mobile for and inspection and a deal.
Also to inspect the engine running in the car Please contact me for an appointment.
Kind Regards
Babak
Can vouch for this being a good engine/build cause i had seen it many time at v&e but wasnt it finished over a year ago?
Cheers
Peter
PM me if your keen on selling the turbo setup, gearbox and tailshaft seperate.
Thanks,
Daniel
Edited by =premo=
INFNT --- Thanks for the vouch. although i dont know you but thanks again.
Premo --- Sory pal, not interested in seperating parts. it give the point of "Package" deal away.
cheers guys
If you change your mind, especaily on the turbo kit. let me know
(almost finished building an RB30/26det which is very close to being the same as yours)
Thanks,
Daniel
you should have sold this about half a year ago before i started buying all the bits for mine but unfotunatly ive got all my bits ready to go together soon, just wanted to say its worth the asking price for sure.
man chuck allthis gear into a vl... with a good enuf gearbox (powerglide or if u want 3spd jatco with transbrake, fully manualised) and ull have a 9second car pretty much lol. a complete motor with some really nice bits for a decent price guys.
s13 skyline. i know that.. but back then it was still under construction lol. anyways thanks for that and good luck with your one. ;)
qnki- thanks for that pal. that was the whole purpose of this biult. as is will run a mid to high 10s. but once again thanks for the bump.
Babak
Guys if you think its too much of a hassel for you to do the labour part of this deal you can come up with a resonable offer for the whole car.
Hello H. and everyone... as i have mentioned in above replies im NOT going to seperate any parts as it give the purpose of the package deal away. i might consider a swap for a car of my choise and balnced my way if you guys think its a hasell to go through the swapping motors and its bits and peices.
Thanks
Babak :P
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
