  • Replies 71
And the HKS dump.
Thanks to the bloke here on SAU that shared these pics with us. :D
:D Thats not a problem and my car used to suffer with boost creep, but not anymore! ;) good ole HKS
yes still R32 ecu, no probs with that at all. still got knock control, perfect idle and cruise, cant complain!
Awesome man!
You dont happen to have a copy of your .BIN file do you mate that we could use as a atarting point for my tune?
Awesome man!
No sorry, Jeff (The Speed Lab) does all my tuning, so you'd have to call him up and ask for a copy of the map, either way he'd be able to help you out. Number is in my sig
No worries man, I am in NZ! ha ha
Hopefully i can achieve a similar sort of result to what you got. Well done bro.
By the way how did you do about your VCT control? I have made my own controller which allows me to set on and off points. Seems to work well.
  • 1 month later...
Hey, I found a 3071 on the net for sale that is direct bolt up to RB25's.
Compressor Housing A/R -: 0.70a/r
Turbine Housing A/R -: 1.06a/r
Does this sound capable of 280rwkw?
With supporting mods, a 3071 should be capable of reaching that power figure with that type of housing. Interestingly though, its usually sold with a 0.5 comp a/r.
Anyway, that turbo should be capable (given its garret IW - with that turb housing it should be), but always remember that the peak power figure your dyno says at the end of the day isnt everything. A 1.06 housing is pretty big. I dont know of that many dyno sheets around here to look at for the 3071, but my guess is that u might experience a bit of lag & a highish boost threshold.
If thats ok with you though, go for it, and let us know the results =)
what you should be asking is "does this sound like a 3071" because is doesn't.
I'd be interested to see a link.
i will most likely be purchasing a gt3071r 0.64 IW tomorrow for my r33 gtst for about $2600 (through my mechanic ordering direct from gcg, inclusive of fitting kit, spacer etc). was going to get a hks gt-rs but they're fairly expensive and take ages for delivery. will post up results once it's tuned, hopefully it meets my responsive 260rwkw goal :)
check the size of the turbine housing mate.
.64 is gt28 size IW housing. .63 is gt30. I know it sounds like i'm being pedantic, but for 2600 you want the right one and not the t2 flanged nugget. It shouldn't need a spacer with the .5a/r compressor housing if it has the right turbine housing
Incidentally. Direct quote from GCG for the proper one last week was 2,450 inc the fitting kit but i do the rotating of the housing and install turbine and actuator and shit like that. Pick up. Doesnt include gaskets
yeah, straight turbo price was 2150. You're paying an extra 200 for the actuator and bracket straight up and there's a premium on the proper garrett IW housing too.
It's not significantly higher than an online seller though and the fact that they are 20 minutes from home is an advantage when the shit hits the fan (if it ever does). consider an ex gate 3076 goes for an average of 1800 these days and it's not far off the mark.
I guess if they're close to home that might be a bonus for you...
ive been looking around myself to buy within the next couple of weeks... ATP quotes (in US dollars) around $1450 plus $95 shipping to your door. Converting that to Australian dollars gives around $1730 Aus delivered to your door. And thats with the proper garret IW housing (0.63 im going for with a 2.75" inlet diameter in case anyone is interested in similar).
Get a fitting kit local from somewhere and you're looking at about $2000.
I haven't bought anything just yet, still looking. Anyone else's hunting experience is welcome.
GCG definitely aren't the cheapest but from a few warranty claims I've heard of they are definitely offer a no fuss warranty.
They can be picked up for around $1800ish with actuator but you do have to shop around. On occasions MTQ have specials on the gt30 and gt35's which sees them down around that price.
What do CRD do the GT30 IW for? Last I checked they were fairly well priced.
sorry typo, meant to say .63. i agree, i thought the price was a bit steep when i spoke to my mechanic, gonna go in tomorrow and have a chat to him. i was thinking the total figure for it to be a bolt on job would be around $2300. but if it really is $2600 for the whole kit, i might decline and just buy an hks gt-rs for $2900 from slide.
oh and there's no way i'll be dealing with CRD, had a couple of really bad experiences with them
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
