hey guys,
long story short, i have bought a set of 6 s15 injectors of a SAU user, and now it seems that 2 of them are from an S14 and are ever so slightly different. have spoke to nissan and they havent got a clue on how to tell the difference. just wondering about getting them flow tested somewhere around in adelaide?
https://www.sau.com.au/forums/topic/193492-injectors-flow-testing/
p.s, they are all a redish brown colour on top, but have different coloured tips. 4 are grey and 2 are a sorta olive greyish kinda colour. and the 2 odd ones also have different serial numbers on top to the other 4.
don't worry about the bottom of the injector. If the tops, where they plug in to the harness,are a reddish terracotta-brown then you should be right. just as long as they are not purple as they are 380cc stock skyline/s14 injectors. You'll probably find that if you try to get them flow tested they'll want anywhere from $20-$35 an injector as they'll sting you for a clean as well.
Someone was asking a few months back about red ones, but they were a alot brigher red than the dull red/terracotta colur of the S15's
Are the 2 odd ones extra bright in red colour?
I think the bright ones were from an auto s14 and were only like 270cc or something.
wolverine,
He didn't say he wanted them cleaned, he said he wanted them flow tested. Buy the time you buy the 6 injectors get them cleaned you may as well have bought new ones.
My injectors were not cleaned before installed. I checked the spray pattern all good, no leaks from the pintle under 60psi pressure, engine has a good idle, AFRs are safe, saved myself a heap of cash got the outcome, I wanted power on a budget, so I'm all for 2nd hand injectors, but thats just my opinion.
wolverine,
understand completely. When i first started my project i was going all out, and learnt futher on in the project to only pay for what i need. I was going to go for the nismo 555cc injector option but decided when i dont wanna push anything over 250kw at wheels, the 480cc s15 injectors would be fine.
By the way i have my car in turbo tune at the moment, they are going to flow test the injectors first then tune her up for me. Hoping they are all 480's :P
wolverine,
i don't see how saving $20-25 per injector (ie. $120-150) is saving a heap of money but if you are comfortable with end result then that's what counts.
you said getting stung for an injector clean and i wouldn't call it being stung. it's just my opinion that if they are handling them to flow test they might as well, for an incremental cost, remove the risk to engine damage.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
