SAUWA CRUISE
Saturday Night Cruise
MEET POINT HAS BEEN CHANGED TO:
Where: Karrinyup Shopping Centre. Karrinyup Road
When: Saturday 8th December 2007
Time: 9.30pm for a 10pm Leave
Maps available on the night
PLEASE NOTE: CRUISE GUIDELINES APPLY! http://www.skylinesaustralia.com/forums/in...showtopic=37588 , Rules will obviously need to be followed. Any breaking of the rules, you will be asked to leave.
ALSO: NO REVVING YOUR CAR AT MEET POINTS OR TURNING YOUR SYSTEM UP LOUD! Stupid behaviour at meets points wont be tolerated.
We would like to get as many cars and people as we can. A huge turnout would be great!!! All Skylines and SAUWA members are invited.
Hope to see you all there!
Cheers
Brad
SAUWA Motorsport Co-Ordinator.
Edited by R DIRTY 3
https://www.sau.com.au/forums/topic/193534-sauwa-cruise-saturday-8th-december/
  • Replies 229
Posted Images
I think the cruise is for SAUWA members and SAU forum members, so if your on here and own a Cefiro/Stagea/Jap Import then your welcome, but we don't want other clubs to be invited, as big cruise attract alot of attention :wave:
I think the cruise is for SAUWA members and SAU forum members, so if your on here and own a Cefiro/Stagea/Jap Import then your welcome, but we don't want other clubs to be invited, as big cruise attract alot of attention :)
lol good luck with that :wave:
Im down like James Brown...
Cruise will be fine as long as no one reposts the cruise on other sites, otherwise prepare for hectik falcadores rocking neons and fully sik burnouts :wave:
I will not tolerate the knocking of Neons!!! :)
As Paul said, it is for SAUWA Members and forum members. So Skylines, Stageas, Cefiros etc are more than welcome to attend. Would prefer it is not posted on other forums.
Cheers
Brad
damn, will be in phuket :P
and im really looking forward to my first all skyline cruise as well.
hopefully next one.
No shit?
i fly out to phuket that morning at 630am, y is it every sauwa cruise that comes up i always have to miss ffs ;)
hmmm....??? i dunno maybe a cruise on aussie day or something, but then i spose ppl will be too busy getting hammered and going to the foreshore lol :nyaanyaa:
hopefully i will be able to get to one soon been hanging for it for a while now
Edited by Nick033
Just got told by work that I'll be spending the first three weeks of december in Newman. Guess I won't be coming :worship: Hopefully I'm in perth for the next one. Hope you guys have a good time :nyaanyaa:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
