Hi....
Ive recently got an R32 GTR and was wondering if you guys notice a dramatic different in the power on say a 30 degree day vs a really cold night...
On a hot day it seems very sluggish in comparison....
How much power would you estimate is lost on a very hot day vs a cold night...
Thanks
Ashley
https://www.sau.com.au/forums/topic/193965-power-lost-on-hot-days/
HEAT SOAK!
Yeah it makes quite a bit of difference for me, I can normally bang in just under a bar of pressure on a cold night, but I won't see past ten PSI on a hot day...
Get some Cold Air Induction and it should do better :rofl:
i think it was a reduction in power of around 1-2% for every 5 degrees the inlet temp goes up. but don't quote me
the main thing you'll notice in super cold weather is sharper throttle response and more low to midrange torque. in fact, the engine is more likely to suffer pre-ignition in really really cold conditions as the charge density at the point of peak torque will be much higher than usual (MAF based ECUs account for this though, and trim the spark advance accordingly)
My understanding is that air is more dense on a cold day there for a better quality of air so ur A/F ratio's are more stable resulting in more power, On a hot day the density reduces causing a loss of power. Don't quote me thogh i could be wrong.
FWIW, here's a definition of heat soak from here. This is why you use a turbo timer, it has nothing to do with loosing power on a hot day.
"When the engine is switched OFF, the cooling system becomes inactive and the residual heat in the engine from the block, head and exhaust manifold are transferred to the coolant and other engine components. The engine temperature actually increases after a hot engine shutdown. This is called 'afterboil' or 'heat soak' and can be damaging to engine life."
No, the heat soak I meant was not getting enough cool air flow to the air intake...
You're talking about something different...
In 32 GTRs the air intakes are tucked pretty high up without a snorkel, so they can heat soak pretty well... the hotter the air, the less dense it is, so the less air that can fit into the cylinders... And without proper cold air induction, it sucks in all the hot air from the engines radiant heat...
And i dunno about you, but I use a turbo timer for the TURBO to cool down, it's not called an engine timer now is it? :rofl:
Very close, the air is more dense on a cold day, so the engine management adds more fuel to maintain the correct A/F ratio, and you make more power because you're burning more fuel. And vice verca so less power on a hot day.
I've never heard that referred to as heat soak before, but maybe i need to get out more. Google for heat soak and you'll see what i mean.
My stock 32 GTR has a factory snorkel....so it doesnt pull any air from the engine bay YMMV.
You're being a bit to literal :-)
Heat soak refers to what happens to the intercooler, i.e when the intercooler cant cool the air enough any more because its aluminum fins are heat soaked with well heat.. typically happens at traffic lights where the car can take on a shitload of heat.
The CAI system can also take on this but typically refers to the SMIC.. thats why a FMIC is alot better as the air charge is cooled much more efficently. hence why I bought the screwball thing
Edited by DECIM8
Heat soak is this, heat soak is that, nooo heat soak is this.
My goodness. Heat soak can mean heat soak on anything. It is as it states, soaking up heat. It doesn't have to be the pod or the motor or the intercooler. Heat soak can occur on a glass bottle in the sun, heck sponges suffer heat soak in hot water.
The terms should of been mentioned "heat soak of the _____".
Edited by KeyMaker
BINGO!
The basic idea of an engine is to ignite an air/fuel mixture and produce power. The more air we can get into a motor, the more fuel we can add to it, the more air/fuel mixture the more power we make. When temperatures rise air becomes less dense (less air in any given space), obiviously when temp decreases air becomes more dense (more air in a given space). Thats why on cold nights (when the car effectivly get more air) we get more power, and on hot days (car effectivly gets less air) we lose power.
:ph34r:
Depends on setup. When my R was stock, it felt like 25% lol... serious
Hence, the usefulness of EBC's
i try to keep away from the whole 'boosting' thing on a hot day
I never like this idea. Performance is total. What if it was 390 on a well planed track day? Would you baby your car? Thats for aftermarket (or PFC) knock sensors are for (not to mention human ears) I reckon the idea's to tweak your inlet temp correction to counter hot days. End results are end results, anything you can make compared to the guy next to you, is a profit smile.gif
this is where high quality coolers etc come into their own and shitty ebay bar and plate coolers start to sap power.
Trent, wasn't there a time, when bar and plate coolers where deemed superior to tube and fin? AVO's 1000hp coolers are still bar and plate... as are upper echelon HKS IC's i believe.
"When the engine..."
For the purposes of the performance arena, i think "heat soak" refers to when the devices that are meant to move heat from intake air -> IC -> ambient air work in the opposite. This is noticeable in stand still traffic, where a IC can introduce ambient temps BACK into the IC -> intake air. This applies of course to intake piping and plenum's etc. F_ck Google.
Meh to stock, 400rwkw+ deems AM pods and a proper CAI necessary for street application (im sounding like a c_nt tonight, must the the multiple personalities) :(
: To answer your original question, i think R's suffer from heat soak more then others, due to the surface area of all the piping. Twin turbos, twin intakes, twin filers, twin manifolds etc. My R when stock felt like a dash mounted marshmallow after a stand still period. Proper CAI's, bonnet vents etc help, but even after you have tweaked all your inlet temp correction values, you have to accept more heat means less power. You can imagine then why 5mins cruising in 5th at 80km/h in 50 weather has such a profound effect on throttle response and mid range (due to the ignition advance the ECU winds into (or should) in those conditions)
read into it, what you will loler'NZ-bungie jump
Edited by GeeTR
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
