Yep. The board crashed (due to a failed RAID controller) and Christian's had to rebuild his database. At first I thought I got kicked out for saying something wrong considering I only just registered the day before! After reading the sticky about the outage, I figured I had to re-register and we're back to normal now, more or less.
rianto has it. and yes they are NOT cheap. not to mention theres still a lot of custom electronics to maintain teh extra options.
Given the composite video input that one can tap into with the V35's, for those who are only concerned with the GPS, I'm thinking one could use the Garmin GVN53 interface as a cheaper alternative. Of course, that would only be an ideal solution for those who don't care much for the stereo and translations. A bit hard for me to tell without a V36 (which won't be until March/April for me) but that's my guess for now. What's your take on this?
up to you. the video in on a 35 has limitations. picture looks a LOT better with RGB applied to it.
I use the GVN53 when I do the 35s. though I use a slightly different version.
if you buy a CKV36 then the full swap is the BEST way to tackle it.
if you read the description they are only installing TV tuner to allow viewing of UK TV Channels. Nothing in the navigation or menus are converted/translated.
its exactly the same to what Chris has been doing, adding an Australian compatible TV tuner.
I think he's still pretty busy... he just finished mine today... I got reverse camera now, although it doesn't tell me 100% whether I'm gonna hit something or not but at least it's helpful to see what's behind me with 150 degree wide angle view....
hm, chris the way you mounted the camera so low, it's very strategic when reversing against a bunch of chics in mini skirts... LOL
    • Same, English is my 3rd language
    • So we need to get together, design a new ECU, that can be mounted elsewhere, leave all the "factory" sensors "in-place", and then any it's not using, when it detects them unplugged, throw a CEL.   Yeah, probably too much effort these days for a Skyline...
    • For some reason the photos aren't loading...?!
    • @Dose Pipe Sutututu ok thanks...i think it will do then :-)  Man i was extremely lucky to even find this engine. I looked for months 😄  @GTSBoy i did not noticed that 😄 ok that is out of the question... @WMDC35 yeah i know but sadly the was not available so i need to use mine "or" some custom one but that would not fit in R34 without some heavy modification... All and all thanks guys...i just want to know if and if not if that "custom" one would be ok for my use :-)
    • Soooo I may have purchased another car from NZ It has Nissan motorsport pedigree... and if I like it, I might be selling the 32 (or my Golf) to buy another one to take IPRA racing.
