Yep. The board crashed (due to a failed RAID controller) and Christian's had to rebuild his database. At first I thought I got kicked out for saying something wrong considering I only just registered the day before! After reading the sticky about the outage, I figured I had to re-register and we're back to normal now, more or less.
rianto has it. and yes they are NOT cheap. not to mention theres still a lot of custom electronics to maintain teh extra options.
Given the composite video input that one can tap into with the V35's, for those who are only concerned with the GPS, I'm thinking one could use the Garmin GVN53 interface as a cheaper alternative. Of course, that would only be an ideal solution for those who don't care much for the stereo and translations. A bit hard for me to tell without a V36 (which won't be until March/April for me) but that's my guess for now. What's your take on this?
up to you. the video in on a 35 has limitations. picture looks a LOT better with RGB applied to it.
I use the GVN53 when I do the 35s. though I use a slightly different version.
if you buy a CKV36 then the full swap is the BEST way to tackle it.
if you read the description they are only installing TV tuner to allow viewing of UK TV Channels. Nothing in the navigation or menus are converted/translated.
its exactly the same to what Chris has been doing, adding an Australian compatible TV tuner.
I think he's still pretty busy... he just finished mine today... I got reverse camera now, although it doesn't tell me 100% whether I'm gonna hit something or not but at least it's helpful to see what's behind me with 150 degree wide angle view....
hm, chris the way you mounted the camera so low, it's very strategic when reversing against a bunch of chics in mini skirts... LOL
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
    • Nice, that's not laggy swtching between functions at all. Could it be less laggy than the factory one below? 😋
