I think the speedo correction is only related to the speed displayed when you're in navigation mode (which again only works in Japan)
I can't remember seeing anywhere in the live computer trip/fuel consumption screen showing the current speed travelled.
Don't think it's gonna do adjustment to your actual speedo needle on the dashboard.
But gyro sensitivity would be intriguing to find out as my compass is out of whack by about 90 degree
(as Chris said the further south in the hemisphere you are, the bigger the discrepancies) because it's designed to work for the northern hemisphere
Do you mean the needle on the speedo on the dash is out? Sorry that's not what that setting is for, it's got to do with the navigation.
Speed Calibration
Under ordinary conditions, the navigation system distance measuring function
will automatically compensate for minute decreases in wheel and tire diameter
caused by tire wear or low pressure. Speed calibration immediately restores
system accuracy in cases such as when distance calibration is needed
because of the use of tire chains in inclement weather.
I forgot that most of that menu is explained in English in the US Service manual for the AV system.
Find it here:-
http://x.infinitihelp.com/forum/local_links.php?catid=19
Sorry to dissapoint but FAIL... LOL
Well maybe an undeveloped language.........it is the newest Language around........ It is a PHONE option.
I have seen it on one other car.
I will try to give you an idea about it later when I have time to sit down a read all the menu's.
Sorry...... this is a really busy week for me. (actually most are)
Cheers
Andy
I give you much credit Andy for what you are doing, I work in ICT and re-programing what you are doing is time & money. $200 is being kind for the work the you are doing.
Offcourse put me in for a NSW Upgrade.
:blink:
Live Life
Bryan
:bunny:
Live Life
Bryan
Will do.. Thanks Bryan
We are just finalizing a few details to make sure the product is as good as possible for the launch.
I will try to finalize all the details over the next 48 hours so we can kick off by the end of the week.
WA is an interesting question. I can not confirm how soon we will be able to offer the installs in WA but it may be possible by way of exchange of the Navi unit.
I will advise as soon as possible.
Cheers
Andy
I have spoken with the developer today and we anticipate have the final product ready tomorrow - 10 December.
I will do the final test in the afternoon and all going well I will be looking to start soon after.
Chris and Rianto stand bye.
Cheers
Andy
i would be very interested in this software also.
Im in the Central Coast area of NSW
Hi Matt
I will be setting up the timetable of installs in NSW tomorrow.
I will be at the Skyline show and shine on Sunday bu not sure if I can do installs on the day.
Cheers
Andy
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
