and how do we do that? Do the el cheapo laser cleaner disks from bargain shops do the trick?
If you have a map disc, keep it in the unit and make sure it reads it.
If you don't have a map disc, see if you can get a copy.
All the units I have seen with a map installed in the DVD rom were an easy conversion. The laser seems to get dirtier with no disc installed.
Cheers
Andy
He I too had mine upgraded to english and it rocks. Thanks andy and everyone for this and especially Rianto.. Great instal
Roll on aus maps now.
:down:
Hey guys had my conversion done last night by Andy. Works great. Only downside is I have seen Andy's car and I will now spend more money on mine!!! Great ride you got there. Very neat.
Thanks again.
A note to those that had their cars done in sydney by nagoya motors (or by revolution electronics) and had a local DVD video player fitted. if you CANNOT find your DVD ROM ANYWHERE in the car there is a VERY good chance it has been stripped to a bare board and shoved under the stock spot and between the glovebox.
IF YOU WISH TO UPDATE YOUR LANGUAGE SOFTWARE YOU CANNOT DO IT !!!!!!
90% of the OEM unit is MISSING! so you guys are stuck UNLESS you replace it with a used item.
I have a car here now from NSW with this EXACT issue. I am going to try other means of updating this one but I see it as a no go. the progam needs to reside in two spots : ON the DVD reader board and also on the main board.
swapping bits into the system from another stripped unit will result in a unit that will reboot every 5 minutes and ask for the jap language disc.
just a word of warning..
further point now that I look closer at this board:
the GPS gyro is also gone. so theres NO WAY to program this thing.
looks like I pass on this one.
(time for me to start my integration into this box by the look of this one.)
Been reading through this quite substantial thread.....
Just want to make sure that I've got my facts straight.
I've just got my V35. It's a 2005 S2 Premium Coupe.
My understanding is that as of today, the english conversion software patch is not yet available for the S2.
But. All being well it will be available from some kind outfit in Russia in the future.
Did I get it right?
Did I get it right?
Almost, It should be ready for the V35 S2 around the middle of this year.
It will be available for the people listed in my signature.
Cheers
Andy
Cheers
Andy
Excellent news!
I shall look forwards to the arrival announcement.
Any ballpark on what investment mightl be required as yet ?
Cheers.
Hey guys. I have an 04 primera p12 wagon. It has the jap navigation screen with all the stuff in japanese. Anyway you guys have a disc i can buy to convert mine to english?
Hi Jason
Sorry, whilst it looks similar the system is different and our conversion system will not work on your car.
Cheers
Andy
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
