So what would your ultimate/fantasy/if money allowed r32 gtst be? Only rules are that it must keep the hcr32 chassi rb20det block and head and rear wheel drive.
Also its gotta be a real world car as in you could build it if you had the money and facilitys.
Give us your complete run down of YOUR ultimate/fantasy/if money allowed r32 gtst including as much information as possible, you can be as indepth as maps for the fuel and igniton too piston, crank, rod, cam profiles, bearings, cooling systems, parts removed for weight saving, wheels and tyres to save unsprung weight, panel replacement, turbo ar ratios, manifold diameters, disc size composite.....just go mad cause as we know its the fine details of tuning that make the difference...turbo oil feed pipe diameters???
But when it comes down to it,its better to post something rather than nothing soooooooo..........Whats you ultimate/fantasy/if money allowed r32 gtst, just remember it must use the hcr32 chassi, rb20det block and head...:D:)
I'll post mine up once the thread gets going...;)
https://www.sau.com.au/forums/topic/19414-fantasy-r32-gtst/
hmm well get a kakimoto wide body kit, that'll allow you to fit GTR rims up the front with spacers and 316's at the back to really get all that power onto the road.
Then for breathing a single cyclonic air pod from the US flush mounted to one of the side guards sucking in a lot of air. A 3 layer (not 4, that's just a waste) intercooler mounted horizontally with a deflector plate in the front bumper opening. This allows cold air to pass thru the intercooler and directly out of the top of the bonnet thru a slit on the pure carbon fibre (no fibreglass) bonnet. This means all the hot air from the intercooler dosen't affect the engine/turbo/radiator.
As for turbo a good t66 for zippiness, not that much lag, sard oil catch tank and oil cooler, lightened fly/cams, a head port/polish to make it 2.4L, a triple plate clutch, carbon con rod, upgraded GTR diff. A subaru sequential shifter. External wastegate and associated venting apperature. NOS Systems N2O kit with atmo release valves.
HKS Silent Hi-Power Exhaust system for true stealth exhaust removal along with a straight thru pipe and a Bee R rev limiter/fuel redirector. Adjustable suspension from TIENS with Cusco braces, mounts and rollcage to tighten up the car so it has no twist at all. Big porsche brakes to control the whole thing.
Get rid of the factory wing, and get some fluffy dice :D That's about all I can think of atm.
And then you'd probably wanna get rid of the back seat/change the trimming to fibreglass, then pay the airline ticket for a big in house tuner from japan to come out and tune the stock ECU (these things are pretty strong) for optimal performance in that climate/fuel. Dump the doors and get carbon fibre door panels and bootlid made up.
I'd rather get a GTS4 and work it tho, i dunno closest thing to a GTR, same price as a GTSt
That's all i can think of atm, but wouldn't it be cheaper to do up an R32 GTR?
https://www.sau.com.au/forums/topic/19414-fantasy-r32-gtst/#findComment-407870
it's a stupid time in the morning and im bored ... so i may aswell make a fantasy car` :(
body
- Trial body kit
- Carbon fibre bonnet and boot
- Flare out guards by 2inch's
- Respray to bayside blue
- Cusco adjustable GT wing
engine
- MoTeC M8 pro ECU
- Garret BB T45 turbo (800hp)
- Trust 50mm External wastegate
- Custom turbo manifold
- Trust exhaust manifold
- HKS super racing bov
- HKS air filter
- Apexi GT spec intercooler
- JE forged piston's
- HKS valve springs
- HKS connecting rods
- HKS crankshaft
- HKS 1.2mm metal head gasket
- HKS 256 ex/in cam chafts
- OS Giken adjustable cam gears
- GFB Pulley kit
- Trust GT spec intake plenum
- Custom throttle body
- Cusco oil catch tank
- HKS oil cooler
- Sard Fuel pressure regulator
- Bosch fuel pump
- Power enterprise 800cc injectors
- HKS fuel rail
- NOS 100hp
drivetrain
- Tein HA adjustable suspension
- Cusco strut brace front & rear
- Alcon rotor's and caliper's
- OS Giken twin plate clutch
- OS Giken lightened flywheel
- HKS lightweight drive shaft
- HKS five speed manual gear box
- Veilside drag spec LSD
- VOLK Racing TE37 (f)18x8.5 ®18x11
- Nitto 555r semi slick tyres (f)265 (f)305
1/4 mile : 10.***
power : 600rwhp @ 2.0bar
i dont think that such an engine would make 600rwhp in 2ltr form ...
but 600rwhp would be nice to have one tap hehe
... :D i would be happy with that ;) ...
https://www.sau.com.au/forums/topic/19414-fantasy-r32-gtst/#findComment-407895
Guest Boxhead
well this might be one long list, but here it is...
either Custom Widebody Gaurds,
Full Vertex Bodykit
Painted 15 200sx Blue
White Volk TE37 Wheels either 16' or 17' as come on, when we go through the fantasy tyres we will have to buy more.
I would use an R33 GTR crank, Carillo rods, Custom JE forged pistons to make it an rb22, increasing stroke to 74mm and bore to 80mm
Rb25det Gearbox with trust 6 speed internals
1.5 Mechanical LSD
Apexi RX6 turbo
some type of 45mm external wastegate
custom exhuast manifold - steampipe
3.5inch single dump into 2x 2.5inch through 2x 3inch cat converters, Twin resonators and rear boxes with twin 3.5inch upswept tips
HKS Grounding kit
Front facing plenum(mood motorsport)
intercooler pipes to suit
PWR Intercooler
PWR radiator
Braided hoses throughout
HPC coating on exhuast manifold, piping and inlet manifold
Power Ported inlet and exhuast manifolds
Cryogenically treated engine internals and head
Nismo 550cc Injectors
256 step 1 cams
Tomei Adjustable cam gears
Titanium vales + head components
mild port and polish to the head
CC'd combustion chambers
Nizpro Crank girdle
ACL bearings
ARP stud and bolt kit
K&N M's Pod Filter
Custom aluminium Air box
Cold Air intake , with duct from front bar
Inlet and Exhaust Manifold's port matched
Jun Oil pump
ARC oil cooler
Baffled Enlarged Sump
Remote oil filter relocator for twin filters.
Power steering cooler
Diff cooler
Transmission cooler
Carbon Fibre Bonnet
hicas lock kit
pineapples
polyurethane bushes throughout the entire car
lexan windows
brass steering rack bushes
DMS shock absorbers
GTR front swaybar
Whiteline custom springs
5Kg flywheel - chrome moly
Competition harmonic balencer
front and rear strut braces
lower front and rear braces
12 point roll cage
Super Steering arms
surge tank+ 2 bosch fuel pumps
Oil Catch can
Battery relocated to boot
New wheel bearings
Motec M800 + CDI + traction control option, converted from MAF, to MAP sensor
Brake Master Cylinder Stopper
AP racing 6 pot calipers for front, with curved vane 328mm slotted rotors, 2 Peice
Tomei Fuel Rail
Standard rear brakes
Braided brake lines all around
Bride Brix front seats with R32 GTR rear, retrimmed in dark navy blue
Carbon fibre interior (door trims, dash etc everything with dark navy fabric trim)
Defi Gauges in glovebox with controller (boost, oil temp, oil pressure, inlet air temp, transmission temp)
Engine shock absorbeR
Polyurethane engine mounts
polyurethane gearbox mount
Carbon Fibre tailshaft
Adjustable upper links (all around)
HKS driveshafts
Custom slineline number plates 'HCR-032'
Gtr N1 spec floor mats
GFB Hybrid stealth fx BOV
Quicker Handbrake Actuator
Nismo 260kmph speedo cluster (in white)
Blue L E D's to replace stock ones. (behind dash, a/c etc)
Aero Mirrors
Full Carbon fibre/ Kevlar Undertrays
Veilside Steering Wheel
Veilside aluminium Pedals
HKS type 1 turbo timer, in ashtray
Kenwood MP3 headunit
Clarion 6x9 speakers in rear
Clarion 6inch splits in front
NO SUBS AT ALL
Direct Clutch - twin plate sprung.
Malpassi rising rate fuel regulator
GFB Lightened pulley kit
Twin Thermo fans with custom shroud
10mm Spiral wire spark plug leads
Electric water pump linked to computer
engine would be running 9:1 compression and a 9000rpm redline to give approx 350rwkw at 1.7bar of boost for daily driving, at meets would run 1.9-2 bar of boost 400ish rwkw
dependent on turbo selection...
https://www.sau.com.au/forums/topic/19414-fantasy-r32-gtst/#findComment-408256
Hi guys, After blowing a turbo gasket, I’m in the process of fitting 2 stock RB20 turbos to my Nissan Syline R32 GTSt. All the work is been done at a engineering firm in Bunbury WA where my dad works.
We are making 2 separate manifolds one for each turbo. Front 3 exhaust outlets to one and the back 3 to the other turbo. There is going to be a balance pipe that goes between both manifolds to equalise pressure into both turbos. We see there is no need to have 2 wastegates so one will be blocked off. All water and oil lines are been ‘T’ . There will be 3” pipes coming off the back of the turbos converging into a 4” exhaust system. Air intake for the turbos will consist on the 1 pod filter, splitting into 2 pipes after the afm then to the turbos. The outlets for the turbos will converge into one tube entering the front mount intercooler then engine.
This project is well underway, and if all goes well will be completed in a month. Before starting this project I had 200bhp running a stock turbo with 13psi, with the intercooler and a 3” exhaust. I have had it down the drag strip with a time of 13.7 @ 167km/h.
I was interested if any one had any comments on how laggy it will be, the power output I might achieve, or any concerns about what im doing. All comments will be appreciated. thanks, Ewan.
https://www.sau.com.au/forums/topic/19414-fantasy-r32-gtst/#findComment-409041
R32GTSTT sound interesting, but i would not block off one wastegate when each turbo is being fed by three cylinders, even with the balance pipe between them it will create uneven boost pressure. There is no reason why you cannot keep the wastegates on both turbos.
https://www.sau.com.au/forums/topic/19414-fantasy-r32-gtst/#findComment-409353
-Wide body Guards
-Bomex Front bar
-Bomex Rear Pod
-GTR Grill
-Phat side skirts
-M3 Winged mirrors
-R34 Nismo Blue Paint
-Carbon Fiber Bonnet
-Carbon Fiber Rear wing (GTR Style)
-R34 GTR Wheels with nittos tyres
-2.4 litre stroker kit
-HKS Cams
-HKS Ball bearing turbo (or maybe twin turbo)
-Trust Front mounted intercooler
-Apexi Power-FC
-Twin muffler 3" titanium Exaust
-Pod filter with CAI petition
-Race radiator
-Oil cooler
-Oil catch can
-Twin Fuel pumps
-Lightened Flywheel
-Twin plate clutch
-Plenty of gauges
-Koni adjustable Shocks
-Nos Nitros System with 50Hp shot.
-Much bigger fuel injectors
-Two bride seats trimmed in Black Leather
-Momo Steering wheels and Gear knob
-Leather trimed doors.
-Playstation2 for roof mounted LCD TV screen.
-Full Rockford Fosgate Sound system, DVD 10 stacker.
-Rear seats removed. NOS display in the back.
-Plush carpet.
-Full length Nismo Stickers
-Polished engine Pipes
450+ HP, in a full VIP setup.
Greg.
https://www.sau.com.au/forums/topic/19414-fantasy-r32-gtst/#findComment-409424
Two wastegates is very useful is a situation like this and theres no reason why one should be blocked off. With only one wastegate, theres a very real risk it being unable to bypass exahust gas from the turbine (because of its low flow) and boost pressure rising to uncontrolable levels.
I guess you're already well prepared to expect a whole lot of lag. The exhaust housing on stock RB20 turbo's are going to be way too big for a 1L 3 cyl engine. Lag city. :)
https://www.sau.com.au/forums/topic/19414-fantasy-r32-gtst/#findComment-409602
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
