hi guy's got a r32 gtr running 14psi and a full exhaust, everthing else is factory , just want recomendation on getting it to sound little like a turbo, after a nice sound when changing gears -the car boogies but just dosent turn heads when going through the gears lol.
any recomandtions
https://www.sau.com.au/forums/topic/194157-mods-help/
the main noise comes from the induction side on the turbochargers
predominately the gtr twins are much quieter than the gtst single turbo setups
you can make it louder by opening up the the intake path and/or removing the restrictions
but its likely to suck in hot and dirt etc - the usual twin pods will make it a big louder
try removing the panel filter and go for a boost around the block - should give you an idea what it will sound like with a twin pod kit
be warned dont do this for long as your running open mounted turbo's any level of dirt could shag the bearings etc
https://www.sau.com.au/forums/topic/194157-mods-help/#findComment-3481694
You could always get a pod or something to get a louder induction noise if you're into that sort of thing. I wouldn't recommend getting a atmo bov, it'll be too much trouble with constant stalling etc.
I honestly don't see why you want the head turning though? Not only are the heads turning going to be people you want to impress, but some of them will be the police as well.
I would rather keep my car looking and sounding as stock as possible on the streets that's all.
https://www.sau.com.au/forums/topic/194157-mods-help/#findComment-3481699
hehe that's what you get for askin technical questions on a sunday.
your best bet is to get a metal pipe to go between your turbo and your AFM (otherwise known as a dose pipe around thomastown). it'll amplify the volume of the air induction and any pressure variations (flutter etc) that your system will have.
i've got a twin plate clutch, which lets the world know when I'm changing gears... usually followed by them looking at my car as if something fell off.
https://www.sau.com.au/forums/topic/194157-mods-help/#findComment-3481750
im running a dual port bov. its handy. has atmo and plumb bak which doesnt cause stalling issues like an atmo coz its returns atleast 50% of the air back into the intake. after a tune it make 190kw. it makes the world look when i change gears.
but if i were ui would go the twin pod setup. would cost u about $200 to get this with some quality pods, ie apexi or k&n ($50-$80) each and then adaptor plates about $15-$20 each. that will give u good induction noises and have a flutter to when u change gears ith a dose.
https://www.sau.com.au/forums/topic/194157-mods-help/#findComment-3481799
Pods will make it louder, I have some for sale as I'm sticking to the airbox to attract less attention (or at least I think I can attract less attention that way :ermm:).
I have K&N pods for sale if your looking for some, not sure how much noise they make though.
Apologies for taking this a little off topic.
nope, should be fine.
My RB26 is loud as, lots of nice noises, just pods on there.
The stock BOV's are quite the noise makers
Do the stock BOV's make a "psshht" sound on some gear changes? Been trying to work out if my BOV's are atmosphere venting or not (its got a tuned ECU and it runs perfectly fine).
So that weird grinding noise that sounds like something is broken when you attempt to slip the clutch is normal? I apparently have a OS Giken twin plate). Of course normal driving its ok, and changing gears is ok too.
Regards,
Gareth
P.S. aren't "dose" pipes illegal?
https://www.sau.com.au/forums/topic/194157-mods-help/#findComment-3481859
With the standard bov, you can hear the 'ppshh' noise, but it's obviously not as loud as a atmo one. With my car, the bov doesn't open until you rev it above ~3krpm. So below that you'll hear a light flutter. This is all with a standard box as well.
https://www.sau.com.au/forums/topic/194157-mods-help/#findComment-3481947
actually your cheapest possible way to get more noise out of your induction would be to remove the factory resonator that connects to your airbox.
how? lol
Access Autoworks in trade place off of canterbury road in vermont/nunawading is the australian distributor for apex'i
https://www.sau.com.au/forums/topic/194157-mods-help/#findComment-3483719
I think at the P1 Xmas party, we need to flutter the Smart...
Wooo woo woo woo
p1 xmax party! omg... could there be a better party...???? one day , one day i tell you i will be able afford such a prestigous annual fee... :P
https://www.sau.com.au/forums/topic/194157-mods-help/#findComment-3484919
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
