Item:
r32 rb26 with modified sump for rear wheel drive has came gears. has 6boost hight mount manifold with garett to4z and tail 44mm external gate and screamer.
also comes with power fc map sensor version with safe tune, 328kw
rb25 gearbox with twin plate clutch.
Condition:
motor is in good condition, turbo and everything else is less that 3 months old, barely used.
Price:
13,000 ono
To Fit: (What car)
all came out of my cefiro, had 1 peace custom made tail shaft if its needed.
gold coast qld
Contact:
pm
Comments:
want to sell all together but can separate the gearbox and clutch from deal, maybe even power fc.
Edited by wolfwood
  • Replies 44
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
