Gday All,
I am currently considering buying a set of coilovers (Tein SuperStreets) for my skyline but I am a bit unsure of a few things.
The main thing I am am concerned about is the legality of coilovers.
Obviously apart from the ability to lower you car below the legal limit, is there anything else which can cause them to be illegal?
Do the need to be of a certain shock design?
Do they need to be ADR approved?
I am in Queensland if it makes any difference...
Any help will be appreciated...
Cheers
ShanO`
https://www.sau.com.au/forums/topic/194555-coilover-legalities/
as far as i know they are illegal for a few reason, i think one is ADR but the other is they dont have spots to hold the brake lines, in saying that there are plenty of cars that have them and dont get pulled up for it, so just make sure the car isn't too low and you should be ok
Let me rephrase that..............
Skylines have coil overs standard, the coil springs go OVER the shocks absorbers.
So coil overs are NOT and NEVER will be illegal.
Citroens have had in cabin height adjustment for over 40 years, so that can hardly be illegal.
Mercedes had and still do have height adjustment via aribags.
Plenty of late 70's Jap cars had in cabin adjustable shocks, so that can hardly be illegal.
What then is illegal? It is spelt out in the ADR's, too low (100 mm minimum) and less than 2/3rds of the original suspension travel.
Simplistically, if your R32/33/34 is lower than 355 mm at the front and 345 mm at the rear then it pretty much guaranteed to be illegal.
Back to the original answer, for less money you can buy a much better shock absorber than a Tein.
Cheers
Not sure about QLD but in NSW you need to have them engineered to have no worries, reason is say you get defected for ride hieght, all you do is go home and raise the car, clear it, then drop it again.
First thing a cop asked me when i raised my bonnet?"Your suspension engineered?"
(Apparently the engineer must measure the car at the lowest 100mm ground clearance, then destroy any residual thread on the coil over that would cause it to go lower).
there's nothing inherantly illegal about coilovers. most cars including skylines come with coilovers from the factory.
Gary....ouch.
Sorry, Matt was having a bad day, I have edited appropriately
Cheers
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
