The Cops Just Threatened To Sticker ......
No not the R33 ......
No not the 350z .......
BUT
Our 2007 Ford Focus stock as a rock hatch. Oh yes folks apparently a window chip is a stickerable offence (or work order as they put it)! :) Now that's the last car of ours you'd think would get a sticker.
I have been pulled over so many times in so many cars that actually i could understand why they would want to sticker ...... this car is only 3 months old and its the first time i've been threatened with a canary. god damn funny.
https://www.sau.com.au/forums/topic/194726-the-cops-just-threatened-to-sticker/
bwahahahahahahahhaha
well steve said that he got stickered in a stock as a rock toyota a couple of weeks ago - because apparently there was tinting on the from windscreen which didnt even exist!!!!!!!
BUT
Our 2007 Ford Focus stock as a rock hatch. Oh yes folks apparently a window chip is a stickerable offence (or work order as they put it)! ;) Now that's the last car of ours you'd think would get a sticker.
If it is a chip then it's deffo bs....but a crack that can't be repaired (like 2.5cm or longer in front of the drivers seat) that can be given a defect notice :D
so like a chip the size of say a half a 5c coin would that be deffo? n they can't sticker u unless they find like 3 things wrong with the car rite?
but damn on a brand new ford focus honestly they must have alot of free time on their hands:P
i was being good .... i had a lot of warning because i went past like 5 of them on Gnangarra Rd until i got to these guys then past about 3 more until i got home! I literally have never seen so many cops in one place that wasn't a big event etc.
Ford Focus the new hoon mobile!
The stone chip is about 2/3rd the way down in the middle of the windscreen - wouldn't say its above driver .... be about 2cms and its not a crack.
It would be awesome to obtain some of those yellow stickers, just so people can whack them on a parked cop car every time they see one... Bet they wouldn't f***ing like it...
actually no they'd just rip it off
and not have to deal with the subsequent $5000 fine that the wa law puts on you for tampering with the sticker
...yuck...
what WOULD be good
is to that the ECU scrambling devie that the US cops have (or at least i THINK that exsists...)
from my understanding you simply wave it over the car n it disables all electrics
or the ecu
or something,
they had it in 2f2f
...so it's GOTTA be real...
i think tonight i'm gonna stay in n watch fnf / 2f2f... haha
the sticker states "must not be removed from vehicle."
so as far as the sticker goes... we can put it in the boot. as long as its not removed from the vehicle
...yuck...
what WOULD be good
or the ecu
or something,
they had it in 2f2f
or the ecu
or something,
they had it in 2f2f
lol NY cops now have cars that auto read a number plate and check to see if its stolen. without the occupants having to do anything. the car also shoots a gummy GPS chip onto cars in a chase so they can track them without causing a hazard to other drivers
true story
true story
prove it?
Well come to think of it - you get a sticker for your windscreen - which you will have to replace ...... but could cop a fine for tampering with the sticker ..... what do you do?
Its a conundrum wrapped in mystery, inside an enigma :D
I think when you get a sticker and replace the windscreen, the window guys put it on the new window . . i think, from what ive been told.
Dan, i like your thinking lol. . rip the sticker off and whack it in the boot haha when you get pulled over and mr plod asks you about it just open the boot, show him and explain that the sticker wasnt any good on the window as it didnt go with the colour theme of the car haha
You tell him to go have sex with him self :teehee:
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
