Make:nissan
Model:late 1998 r34 gtt skyline
Milage:26700klm
Transmission:manual
Colour:midnight blue
Currently registered? yes 7 months rego
Price:$21900
Contact:0422172482
Comments / Modifications: nismo front bumper,
factory xenon headlights
clear front indicators
rear red foglight like on gtr
tinted windows
hks coilovers
19x9.5 impul starcorp rims with fat dish!
front mount intercooler with polished piping
full 3in cat back exhaust (awesome deep sound)
bosch 040 fuel pump
blitz super sound blow off valve
blitz air filter
blitz boost gauge
full car alarm with immoboliser and turbo timer
momo steering wheel
razo gear knob
r33 gtr seats
blue l.e.d globes in dash console and centre gauges
car made 197 rwkw with power fc but have sold it seperately
i am the 2nd australian owner of this car and have had it for nearly 12months.
i bought it with 18000klms on the clock and it now has 26700klms. ive had it serviced only at
belgarge and autsport using only royal purple oil and nismo filters. just had a service at 25k at
autosport and they said the car is in perfect mechanical condition. this car is a real headturer and will not dissapoint!
All inspections welcome
willing to take off parts for a cheaper price i.e, wheels, coilovers, exhaust, seats etc.
so if any one has the standard parts pm me with your offer.
if you have the standard wheels and seats will sell car for $19500
Images:
Edited by yld_33r
https://www.sau.com.au/forums/topic/194741-rare-midnight-blue-r34-gtt/
  • 1 month later...
I was looking at this car myself about 2 years ago back in Jan 2006 when i was looking around for an R34. Pretty neat car honestly. I still have pictures of it :(.
Unfortunately i'm going to sell my 34 as well :D. Good luck anyway.
would u mind selling ur split/dump pipe? Also will take the front mount as well if ur planning on selling them sepaerately ;) ?
yeh mate am willing to sell them, im just going to leave it as is for another week or so and see if i can sell the car as is, if not i will be returning the car to stock.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
