^^^ your dreaming kid... "with great power... comes no economy" lol
indeed it was on standard boost, i have the readouts somewhere here!
ive never boosted that car man, never felt the need to
now with the gtr i dont think im ever going to lol
Werd to that grasshopper, as Confucius say "With great power comes great fuel consumption"....or as I say "Power=Fuel" :w00t:
how much does a tune cost at dr drift? its in dandeong yea? looking to get more power / economy out of mine.. i get srsly shit all in my n/a.
everyone seems to recommend dr drift i think i'll be going there :w00t:
He is in Brooklyn, just passed the city on the other side of the Westgate.
Edited by abu
just a little update seemed everyone has bigger stock power figers then me :)
so i had a look around my engine and found a disconected vacum hose from the boost solinode that goes into the cooler pipe.
seems to drive better and have more power lol
Would like to see what mine makes just out of curiosity.
GTST with exhaust and boost tap to make it run bout 9 pound.
BTW, I have no idea of the difference between pound, psi, bar, etc. And am not sure that im using the correct term. I think the car runs 7 pound/psi/whatever as stock and now its on 9.
But im guessing around the 150 mark atw considering no front mount at all.
$120 mate he charged me for a full diognostic it sure was interesting :D
Whats involved in a full diagnostic? I have had my R33 for 4 weeks now and want someone to go over it with a fine toothed comb, then dyno it.
i went in today for a diagnostic coz my car always misfires. he suggested spark problem so i'll have to get onto that. while i was there my stock r33 made 140.1kw while stuttering lol. he said it wasn't a power run though or something like that. dunno wat that means? anyway attached a pic i took of the screen
140 will make a few more when you sort the sparking issue...
fark my lemon i cant belive i forgot to hook up the vacum hose to the cooler from the boost solinoid its beeen off since i thought a fixed the leak and ran it on the dyno with it off too, :P
it seems to have more power and spool faster then i heard another hiss like a blow off valve while on boost farken old hoses.
ill have to go though every last hoes now......................
it seems like i get the hoses under normal boost pressure and the air finds a new weak spot in the system to escape.
when i bought this thing i tramped down some road and it sucked me on the seat and felt bloody awsome seemed to just keep pulling i loved it........
so i know what it can do arrrrrhhhhh :P
sometimes some 'stock' cars can seem to make more power than other 'stock' cars due to a leaning out fuel pump. I know cos this was the case with mine... Dealer just told me it was a 'freak' and that some just made more power - all it was doing was running lean..........
...looking to get more power / economy out of mine.. i get srsly shit all in my n/a.
I've seen so many people go and put extractors on, get their engines tuned up, do custom air intakes and exhaust systems, etc all in the name of getting 'better economy'...
This *might* work *if* you drove using the same amount of power as before, but with less fuel being consumed... but from experience if you have more power, you tend to use it... so worse economy!
i do suburban driving and drive about 30 mins to work and back and im lucky to get 200 k's from my tank, yeah i put my foot down a bit but not all the time it should be better economy then this..
i thought a dyno tune could possibly fix this problem..?
Edited by 4Door_33GTS
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
