I'm looking at replacing my front rotors and calipers with those off a R33 GTS25T.
Has anyone done this before?
I have heard they bolt straight on, and apart from a brake bleed/fluid, all should work just fine?
Cheers, Chris
https://www.sau.com.au/forums/topic/19587-r32-gtst-brake-upgrade/
I think the only differance is that 32 GTR rotors are a 2mm thicker than 33 GTS25T, and the same diameter (296mm compared to 280mm on ours)
A set of R33 GTR Brembos would be nice - but they'd cost a fair bit
Do you reckon that the master cylinder will still be OK? I can't see any dramas with swapping calipers, so it should be OK. I'm hoping to swap mine over and pay the differance for the calipers and get some DBA slotted rotors with decent pads, probably from Race Brakes or somewhere similar
Master cyliner will be fine, the brakes have just got bigger pistons giving more force but they are not large enough to cause a problem. I saw some 33 Brembro on performance forums for 1600 which is a good price. But i want the option of being able to use 16'' wheels so the 32 gtr brakes are the go and with decent pads and braided lines will give good performance for the lighter gtsts like ours.
Guest Boxhead
im with slip here, eheck your pads, if low, replace with some decent pads, then get some good fluid in there, i used the motul race stuff, its apparently better then dot5.1....
and it made a hell of a difference, you will be surprised the crap that will come out when you flush your system.
For WW2 you will need things for GO mate, non of this slowing down bisso. Look at grepin, he's now got 60% more power than stock and his brakes and fluid are the same from when the car left the factory in Japan!
Im with Slip,
I've got an R33 gtst
bought a set of DBA slotted rotors, only to put them on and find
that both the width and ofset were wrong..
actually damaging the rotors
with that DBA refused to take the rotors back even after they assured me they would ... so if you go this way..check them first
Didn't end up going with the R33 GTS25T brakes, I got some slotted rotors and Race Brakes pads (of Clint32's car which is getting GTR brakes
Didn't think they would make much a differance, but I was wrong!!
Stops heaps better than before, I can now get that good g-force feeling under acceleration and braking now
Will need a track day to give them a good test, but so far so good
Also, big thanks to Clint for helping me out with them - cheers mate
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
