Hi all.
Make a long story short. Basically I just got new tyres, tyre guy said all he was going to put on the form was he sold me tyres, and didnt fit them due to my having wheel spacers. So I asked him why are they a problem, his reply...
"Because the spacer its self can move and loosen the wheel nuts." That and the obvious hub centering an loading thing. Now I can understand this being true with the cheap nasty slip on spacers. However if you click the below link, thats my old cheap nasty spacers, and my new shiny custom made ones, to fit my hub, and my wheel. I had to use a rubber mallet to put these on the car.
He STILL seemed to think this was an issue. Obviously its in his best interests for me to have a problem because then he can sell me new wheels. That said I do understand they are still illegal, and obviously for a reason.
Basically how worried should I really be?
http://www.skylinesaustralia.com/forums/in...t&p=2432648
https://www.sau.com.au/forums/topic/195893-spacers-yes-again-yes-ive-searched/
Wouldnt worry at all about it. Ive made, fitted and used homemade spacers before, fitted my own tyres and wheels with no dramas ever. With your new ones which look like they centre the wheel and locate it perfectly, with the nuts just holding the wheel to the spacer you should be fine.
If your that worried, im not sure if they make such a thing, but get a set of nyloc wheel nuts which cant undo. If the wheels are alloy, which im assuming they are cause no one uses steel rims anymore, the alloy itself acts like a springwasher and the nuts really bite in hard when you do them up.
Its actually the smart thing to do, no matter how well the spacers fit onto your hub and wheel setup, if they are illegal, then thats all your insurance/police need to shift blame if anything happens, if he did not tell you then he would be liable if anything did happen.
The only way to have legal spacers on, is to weld them onto the hub, and then get them engineered,(coming from an rta inspector when i got defected for 30mm bolt ons)
That said, as far as drivability goes, those spacers you've got are fine, its the legality of them he was talking about mainly.
Thanks fellas. I dont disagree with what they did at all. I mean they cant be liable, so from their business's point of view its the right thing.
My question was more so why he said they were illegal and a problem, Id never heard of the movement issue before.
its because the cheap nasty spacers move an make the wheel nuts come loose and also because your widening the wheel track from standard, your modifying a standard part of the car and it also puts extra pressure on the wheel bearings. i made hub centric 10mm spacers for mine (like yours daveo) and when i went over the pits i asked him about them and checked my track and said because i had modified it it wasnt legal, he let it go but because i made them good an i made him some. also quite a few businesses wont do work on cars that they see can be a problem and the customer coming back with a lawsuit against them
Edited by turboedsloth
Haha gotta love the mutual favours :)
But yeah as was said, some spacers do compress over time depending on their quality and material = loose nuts = bad.
this is why its recommended if you ever get new wheels, you tighten them after a short drive to make sure they stay tight, even if an air gun was used first time round.
Edited by T187
http://www.skylinesaustralia.com/forums/R3...32-t169774.html
i had them 'slip on spacers' and every time i came back from some dori, my wheel nuts where loose (all of the fronts)
then i decided to take the wheels off n inspect the nuts, the thread were f**ked coz it wasnt loosening off the car, it was being pushed out...
ended up buying $200 worth of wheel nuts/studs.
f**k the slip on shit, get some bolt on spacers they may be around 50-80 each but cant be worse then ur tire flying off mid drift.
With slip ons, I usually tighten them up on the car. drop the car, tighten them up. drive the car around a bit turning left and right and tighten them up and then I am good to go. They usually have a bit of a turn left in them when I do it so they do seem to settle as you load. This was when I was running 2 slips totalling 18mm (10+8). Prior to that I was running 3 (5+5+8).
A tyre shop has told me that you only need tyres speed rated to 100km/h and a million other interesting facts so I wouldn't worry too much about what they say.
i refuse to use slip-ons, in drifting the abuse always ends in tears, bolts -ons are the only way to go....
but in your case pull the wheels and tyres off and take them in to your tyre place of choice... they cant refuse what they cant see.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
