Hey
My coolant overflow bottle is filling up and spitting coolant out of the "hole" on the very top of the bottle.
Last weekend when i gave the car a bit of full throttle action i noticed that the stock temp gauge was sitting just between the half way mark and the full mark, so pulled over but left the car running, couldnt see any coolant spilling from any pipes anywere, but the overflow tank was completly full (didnt overflow though) so i drove the car back home very slowly.
One thing i have noticed is that when the car is up to full temp the radiator pipes are never hard (pressurised) ,in my old car the top radiator pipe would always be hard as a rock, mine is soft and almost feels like its empty, so i thought maybe the radiator cap is stuffed, went out and bought a new cap which changed nothing, pipes still soft and coolant overflow bottle is filling up.
The coolant system is always full and i check the level all the time, there are no leaks anywere at all, the waterpump and thermostat are nissan items that were replaced about 6months ago.
Any ideas what the problem could be? im thinking possibly a blocked radiator?
Any suggestions would be awsome
Cheers
https://www.sau.com.au/forums/topic/196137-coolant-overflow-bottle-overflowing/
At a guess I'd say your pressurizing the cooling system ! do you get any hydrolic lock on start up ???
What exactly do you mean by hydrolic lock on start up?
The car starts and drives perfectly.
By the way, i forgot to mention that after the stock water temp gauge went between medium and high i went home and plugged in my power fc (still on the stand base tune) and went for a very slow/quiet drive , the water temp sat on 95deg most of the time, which seems a bit high to me?
I have the same problem except mine just blew the radiator recently. Get under the car and check for leaking welsh plugs. I replaced the radiator cap and kept topping up the motor and flushing it until I realised it was a stuffed welsh plug which would suck air back into the motor which caused a massive pressure build up when I turned off the motor.
(I happened to accidently pop mine into the block so I wouldn't do what I did to repair it)
he has already changed the cap. what about a air lock? when you go out to the car of a morning (or anytime where the car has sat for 6-9hrs) is there anything on the ground?? leaked coolant? trace it back to where its comming from.
1. get your radiator flushed (specially with summer now)
2. check all welsh plugs and hoses for leakes
and hoses arnt spose to be rock hard, go to repco or somewhere and feel new hoses :whistling:
The car never leaks coolant ever, the only time it has leaked coolant was yesterday when the overflow oveflowed lol.
I will give the car a flush today and change the coolant
I meant the hoses are spose to be hard when the car is at full temp and the coolant system is pressurised, lol , but mine are always soft when the car is at full temp, probally because most of the coolant run into the oveflow tank and then overflow, hence not much pressure in the system because there is hardly any water actually in the motor.
I've had 2 cars that have done this, it was headgasket both times.
I hope not lol, but somehow i dont think so, as the car isnt blowing any white smoke, its not losing coolant apart from when it spews its out the overflow, the car still runs perfect.
thermostat may not be opening fully or siezed partially open
Thermostat is about 6months old and was a brand new nissan item which was replaced when i got the waterpump/cambelt etc etc done.
Looks like i may have found the problem!
Took out radiator and the top and bottom radiator hoses today, coolant was suprisingly nice and clean, but the top raditor pipe was full of rusted metal crap, the big nipple on the intakemanifold were the top raditor hose connects to has rusted away at the front of the nipple (see pic) which has obviously been rusting for a while sending rusted grunk crap threw the motor/radiator etc etc, which has probly blocked the radiator causing the car to overheat, the bottom of the overflow tank was full of brown rusty water which i didnt spot before hand.
Possibly one of the previous owners didnt use antifreeze, or not enough antifreeze which has caused the steel nipple on the intake mani to rust pretty quickly, hence causing my problems.
I will try and give the nipple a bit of a clean up and get most of the rust off, then flush the whole system heaps times, instead of get the stock radiator flushed/cleaned i might get an alloy one instead (will help with cooling when i start doing some track racing) ,and some new coolant ofcourse, i will update this thread when i have everyhing back together and hopefully fixed.
Pics of rusty nipple!
Cheers for your help :)
Turns out the radiator isnt the problem (i dont think).
Got the car running tonight (new alloy radiator and coolant) and had it idling while i was toping up the radiator wating for the thermostat to open, the car was idling for atleast 20mins, but the thermostat never opened, the water level of the radiator hardly dropped even when the car was up to full temp, the bottom radiator pipe stayed cold so im guessing the thermostat isnt opening.
That should have been the 1st thing i shouldve taken out and tested, i just ruled it out because its only about a year old genuine nissan item, not sure how it can all of a sudden go faulty, seems weird to me, the car was running fine and didnt overheat after nissan had replaced the thermo,waterpump/cambelt etc etc.
Anyway, what brand of thermostats do you guys use? im not really to keen on getting another nissan one if its just going to go faulty again (i bought the nissan thermo in the 1st place because if thought it would be the most reliable one, i guess not).
Cheers
you have a blown headgasket
Why do you say that?
The car does not blow white smoke, it does not use water, there is no oil in the water, there is no water in the oil and the car runs perfect! i dont have any of those issues.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
