  • Replies 318
Check oil level, if its on low, chuck in another 2 litres, if its on high, chuck in another 1 litre.......you don't have to...but then after having done 5 track days doing the above, car never had any problems....
Bring extra oil, power steering fluid, jack, some tools. I bring everything just in case things go wrong.
How'd you go mate???
i will call tomorrow lol, was on my ps3 the whole time :domokun:
shopping for a new helmet in the next few days, and fireie and a long sleeve shirt n other crap i mite need,
hopefully i can dig 2 sets of cheapo 17s in the forum before the day..
lol @ net talkers!!
Sheng - if you are after a helmet, check the SAU NSW Members section with the sponsers/buys etc
Goto Sydney City Motocycles in Lane Cove, with your membership card - I saved about 20bucks!
